Tail light assembly replacement
Jab226
Hello all! I stupidly backed into a garbage can in my brand new 2015 and needless to say I cracked my tail light. Can anyone tell me how to replace the tail light assembly? Thanks so much!
Pull the bulb access panel, unplug wiring harness, remove two 10mm nuts, pull firmly away from the truck. Reverse order for reinstallation.
Help - I backed into a concrete post with my '06 4R. I replaced the taillight assembly on the right side and the turn signal and reverse lights do no work. I checked the bulbs and sockets with a battery and by switching right to left. I also checked the fuse boxes. Am I missing something?
JLRehm
[MENTION=117608]jlrehm[/MENTION] , wrong forum friend, try over in the 4th gen section (however its likely some of the guys here have your answer)
Philthyphilthy
