Talk me out of a Land Cruiser
The big difference is this:
IMG_3907.jpg~original
The parts underneath the LC are a lot bigger and stronger. The 4runner is basically maxed out on durability with mild mods. The LC can take a lot more tire in stock form. And FWIW -
5th gen LT:
11378890_800294373418133_1754306336_n.jpg~original
Stock LC 200;
2010_Toyota_Land_cruiser_RTI_r34_lr_twist.jpg~original
Don't want to be in a pissing match either.
It seems you are comparing apples and oranges... One random offroad pic vs an RTI type ramp... Not sure that flex is better than a trail with KDSS.... Not even close to LT.. Mine drops to the top of the tire below the slider with 34s... Then again, I have no swaybar on. so it's not even fair.
To say a 5th gen is maxed out on durability with minor mods is totally opinion. I would say there is plenty of room for more. Yes the front end is the weak link... But it's really not that bad at all. 35s should be no problem if some caution is used. Plus... if it goes it should be the CV. Which can be swapped on the trail pretty darn easy. I've seen FJs on 35s (with the older weaker stuff) being wheeled by wild men. I've also seen 5th gens take quite a beating. Also, plenty of Tacomas on 37s without any major problems. Same IFS.
It's hard to really do fair comparisons of capability... Every trail and area is different. I know a built 5th gen can run the rubicon... Bimrunner has done it, so that seems like a "real" trail to me. There are probably some 200s that have done it also, but I'm not sure. Maybe not. I just think you need to give the 120/150 platform a bit more credit. Its not as beefy as the 200 platform, but its got enough for what most anyone would ever want to do. So to guide someone towards a 200 series, saying it is a better platform to build on is misleading as hell. The first question should be... what are your plans.. priorities.... It might be better.. it might not. IT might be worth all the extra money to them... but it might actually be less capable for their use case.. Say you wanted to keep the warranty.... So no locker possible on the LC in that scenario.... The 5th gen will blow right past it... This is the norm for most folks.... So I actually think a 200 fits in very few hard core offroaders wheelhouse. It's great for a mostly hwy/tow rig with occasional adventures off pavement (mainly someone who wants the luxury or power). It is also probably great for someone planning on insanity and willing to chop it up and run 37s+... but what about all the folks in the middle of those two different ends of the spectrum? That is where the 120/150 platform fits nicely, IMHO.
[MENTION=118321]Jetboy[/MENTION]
Are you sure that's a long travel on that 5th gen? It looks like he's running 32" and maybe no rear sway bar on his vehicle...
This is from a while back when I think I hadn't installed my rear extended swaybar links on my 33's, it's not stuffed or angled nearly as bad as the 5th gen in the picture, but it looks a bit close.
20121230_140957_zps0c9dd1a0.jpg~original
Listen to Russell Peters.
I don't take many pics..and drowned my phone the other day.. but did have one on the cloud of a flex situation on the trail....
Ah okay, I guess it is a Long Travel... I'm not sure why it looked odd to me...
The pic JB posted was not my truck. That is [MENTION=76550]cbielat[/MENTION]. Not sure if he had LT rear in that pic or not. He does have LT/mid:fish: +2 front.... That truck does go pretty good....
Are you maybe passing judgement on the 4runner a little too soon? The 5th gen has been out for all of a few years; I think there is more than enough of a starting foundation which modders and offroaders can work with to turn it into a very reputable trail rig.
If we are going to judge a vehicle's true offroad prowess solely based on the size of its differential, then by that same logic I guess we should consider the Land Rover Defender and Jeep Rubicon to be subpar offroaders?
The 4runner pretty much has all the same offroading tech as the LC 200 series: Rear locking diff; KDSS; solid rear axle; fully boxed frame. I agree some of the components on the 4runner are lighter duty compared to those of the LC 200, but then again the 4runner is a much lighter vehicle, as someone else already pointed out.
I admire the LC 200 series for sure, and if I had the money to buy it and spend on extra gas, I would certainly own one. But for the average SUV owner or offroader, the lighter weight, lower cost, and simplicity of the 4runner just makes more sense, IMHO of course.
FYI, no locker on lc200 in north america. It was offered in the 100 for 2 years (98 and 99) I think. But it's been 15 years. It does have some cool electronic gizmos... Like a feature that will lock the rear wheels to help the turning radius.... Maybe the brake assisted traction control is that good... but I seriously doubt it.
Also read this http://expeditionportal.com/why-the-land-cruiser-is-the-worst-selling-suv-in-america/
In summary...
The design of the 200 is lifeless and benign, something that sells poorly into this intended demographic (this is not a commuter car). The performance is adequate, but uninspiring with the 5.7L V8 being the only attribute of note. On the trail the mammoth proportions and limited clearance will make anything more than an unimproved road a potentially costly exercise. The traction control system and KDSS are brilliant, but they can write checks the rest of the trucks simply cannot cash. I also say this with months of time behind the wheel of the 200. I even crossed Australia in one, however it was fortunately modified for additional clearance, but remained – blah.
Not really trying to get in this pissing match, but I would think the LC has to have a heavier duty rear axle to handle the extra 1,000 lbs and 100 hp...
It does. Also the LC200 has/had a supercharger option and 25% lower gears. So the LC can produce 504hp and 550 ft lbs. Almost double the power and torque of a 5th gen. The 4.5L diesel produces about the same tq. Combined with lower gears, it needs to be twice as strong.
It's safe to say you're unlikely to ever see a 5th gen do this;
Or this - because the LC200 has an OEM snorkel, the 5th gen has no snorkel option other than DIY.
Again not trying to be a smart ass, but those are two things I would never want to do in my truck. A swamping...and burning up the tires by power breaking a truck with a torsion center. Neither are very impressive feats. However, I would like 500HP ;-)
The supercharger is also discontinued.... Right? It just so happened they had the Tundra motor to piggyback on. Doubt Toyota would have invested much time in getting it certified in the US since only 1500 total LC units sold in a year in US.... That video is obviously from Dubai.... Do you have any idea what people spend to get cars done over there....Million dollar rigs are a dime a dozen...
It shocking Toyota bothers importing them at all. 100% sure they loose money on that vehicle here.
The ARB snorkel for the 5th is just around the corner...
A supercharger is also going to happen soon via URD, although I'm not too interested just yet. Time will tell if it is a good choice....
As far as off-road goes... I've never had a single moment of wanting any more power at all. I have had moments of wishing for dual cases or a better reduction gear... that should be very doable, but other things are higher priority.
The road is the place where the power comes in handy and that is definitely where the 5th gen could use some major improvement and looses out big time against the LC 200. Towing with the 5th gen is also miserable. It is adequate power though (for non towing situations), and the motor seems pretty bullet proof and up for lots of hard work.
So being able to do burn-outs is now part of the criteria which defines an SUV and offroader?
I mean the S/C Toyota 5.7L V8 is a cool concept, but certainly not needed for offroading or basic truck duties, even for the bulky 200 series.
Snorkel is forthcoming for the 4runner. I'm pretty sure there is already one developed for the Land Cruiser Prado (which shares the same platform as the 4runner).
The more I hear people complain and whine about the 4runner's lack of power, the more I realize there are 3 different groups of 4runner owners: those who don't give a crap about the engine; those who value durability and longevity over high-end performance; and those who want to get "max" performance out of their 4runner and post it on Instagram (bro trucks).
The 4.0L V6 is nothing special, not in the least bit. And certainly a little bit more torque would have been appreciated. But if you have spent any amount of time actually using the 4runner on rugged terrain, you would know that the engine is more than adequate for getting the vehicle over pretty much anything that the frame can actually clear.
This is a Toyota 4runner we are talking about here. If you want something that can smoke tires, and hustle between stop lights, the Jeep Cherokee SRT or the BMW X5, or any number of other performance crossovers would be your ideal vehicle.
To be fair, I'm happy with the 2UZ-FE; it's been a bulletproof engine. Cruising down the freeway at 80mph on 33's and armored up while barely touching 2100rpm is a nice feeling. Not to mention having that torque at the low end means I rarely use 4Lo unless it's really rough on the trails. I'd love the 1UR-FE at least (newer, lighter, slightly more power and economy) , that was one of a handful of major reasons I quickly passed on the 5th Gen when it came out. It's not so much an issue of wanting a BroDozer, but having reserve power on demand at low end on top of being armored, lifted, and loaded down with gear and mods, I like overbuilding things and having reserve is always good in my book.
The V6 is no slouch and had my history with V6's not been coloured poorly by my old S10 blazer I'd probably be running an FJ or V6 4/5th Gen. But I have come to expect that low end torque and power. The 3UR-FE with Supercharger or 1VD-FTV with Dual VGTs are my dream engines, but that's mainly because I'd want to run the beefier drivetrain out of the LC200/Tundra and have plenty of get up and go left over (and to do a 4-wheel burnout with 35" MTs and make most sports cars at the stoplight blush).
Deep water is just part of life in the west. Roads cross rivers. If you want to go in the spring, water is going to be an issue once in a while. I have had to turn back because I was concerned about water fording depth. There are trails I wouldn't try because I know it's too deep to even start. Another nice benefit is that any water deeper than about 36" means no atvs!
The TRD blower is no longer for sale. But there are a number of aftermarket options for both supercharger and turbo systems. The big difference I suppose is that the 5.7 internals are up to the task. I don't think the 1GR dual VVTi are built to take much power. And the 5.7 drivetrain is also up to the task of handling the power. The 5th gen isn't. Does it really matter for doing burnouts? Not to me. Would it matter for turning big tires - absolutely. If you're starting with a big heavy SUV - it's gonna need to be built like a tank. Even more so if you want to laden it with another 1000+ lbs of bumpers, slider, skids, and such.
Dual cases should be do-able right now. I'm pretty confident a Lefty would bolt up. Just a few driveline mods and you're in business. I'm kinda partial to dual cases with the 4.7 gear set myself. My take is that the 5th gen doesn't perform well at all in 4hi in the dirt. It's probably tuning, but it really struggles to maintain speed on steep mountain roads at high elevation, even pedal to the floor. So you really do need the regular low range for normal logging road duty. I wouldn't want only an ultra low gear without something changed to perform better at 20mph. 4hi just won't do it. 125hp at 2000 rpms would go a long way.
I realize neither NY or TX has much for high elevation, but I think you'll change your mind on whether more power would be useful if you ever end up on a 20* slope of river rock out of a stream crossing at 9,000 feet. Sometimes you just need some juice. The 4.0 doesn't always want to give it to you.
As I said earlier, if I had the money to spend on a 200 series and extra gas, I would have one by now. The LC 200 series definitely no slouch for a lot of different reasons, some of which you mentioned. I have seen plenty of pics of armored up, fully rigged up 200 series, and yes I find myself drooling from time to time....:biggrin2:
All that said, it is bigger and heavier than the older Land Cruisers (which in all fairness, is a common trend for most vehicles nowadays). And while the 5.7L engine is a certainly a torque monster, which most truck guys can appreciate, I've heard it burns through fuel at a prodigious rate, even compared to other modern V8's. The LC 200's $82k MSRP also doesn't help; that's a lot of money to spend on a vehicle intended to serve as someone's "trail rig." For those reasons, I consider the 5th gen 4runner to be the more ideal offroader/overlander/recreational truck for most enthusiasts.
I think there is something to be said for a plain and simple, small but capable platform like the 4runner. It's a tried and true formula that has worked well for the land cruisers of old and other BOF SUV's like the Jeep Wrangler and Land Rover Defender. None of those platforms were ever known for having the most advanced and powerful powertrains; rather they were standout's for having adequate and reliable performance.
The 4runner's engine really hasn't been tested in boost applications (turbo's and superchargers), so maybe we should hold off on passing judgement until we see some results.
Also, I'm still not understanding how the LC 200 is more "tank-like" and robust than the 4runner? Yes, the LC has bigger components, but it's a bigger vehicle to start off with. The 4runner has less of a load to contend with.
I know we are getting into very subjective territory here, but I've driven my 4runner across plenty of logging roads and many rutted out old hunting tracks. The 5th gen's 4Hi works absolutely fine in that kind of terrain.
I can imagine out west that the engine power is somewhat reduced at higher elevations; to be clear, that is an engine issue, not a reflection of the 4runner's 4wd performance or lackthereof. I have more than enough power for the backroads that I drive, and I rarely find myself going over 20mph simply due to the lack of visibility around corners...I would likely have no reason to go much above 20mph either on a high elevation mountain logging road (safety always trumps convenience IMO).
So no one will argue that the 4runner's engine is faster or more powerful than the 200 series'...but the 4runner's engine does give you enough power to move the vehicle and cargo, and it does that with much better fuel economy than the 200 series, which is much more important to me due to all the driving I do.
It's a tradeoff: you want more HP and torque, it's going to cost you more one way or another. You want a cheaper fuel bill, you'll have a less powerful powerplant to work with. I don't see a right and a wrong answer; but I do think there is a reason there are many more 4runner owners on the road than there are LC 200 owners.
I've had my truck above 12k a few times off-roading. It does make a big difference in power... But I had no issues in 4Lo situations. It did have to work real hard on the road though.... and I only had 285s at the time. Curious to see how it does next summer. I've always heard a good formula for a crawler type rig is under powered and over geared... That's pretty much been what every legendary Toyota offroad rig has been.
You would be shocked how steep some of our hills are down here in Texas. It's not all flat ground like most people think. There is some very extreme steep terrain in central Texas. And some crawling terrain that is as difficult as anywhere in the country (stuff impossible in anything but a buggy on 40+). Plus we actually have some mountains down in big bend... Just hardly any public land, and the elevation is all pretty low.
Anyway, I agree some more power would be great. That is an area where the 5th gen sucks pretty bad. But it still does get the job done... It just has to work for it. I'm curious to see if it can handle FI. I'm guessing it is going to need pistons and rods to make serious power, but low boost + 100tq down low might just work fine.
I would suggest the fuel economy either goes away entirely or actually flips in favor of the 200 once you go to say 37" tires. That's one of the reasons I think it's a better base for a more heavily built vehicle. Actually I'd even bet that a LC200 with 1000lbs of bumpers and other crap bolted on and 33" tires would best a 1gr with the same setup. On the bright side, there is an OEM 40 gallon tank for the LC200, so at least you can carry enough.
OP, what do you want out of your vehicle?
If you want the offroading pedigree, go anywhere utility of the older land cruiser (think 80 and 100 series) then the 4runner is your ideal rig. I forget who it was, but someone made the statement that the 5th gen 4runner is the spiritual successor to the old land cruisers...it's a basic, spartan but reliable and tested design/platform.
It pretty much has all the offroading tech that the 200 series land cruiser does, minus the big v8...and IMO, while the V8 has awesome grunt, its horrible mpg and added complexity will cost more $ in the long run. The 4runner's V6, which I agree is somewhat gruntless at low/mid RPM's, gets the job done well enough and is more than adequate for getting over difficult terrain when in Low4.
As much as I admire the 200 series from a technical standpoint (awesome v8, all kinds of comforts and amenities) it is simply too big, too expensive, and too diluted (relative to its predecessors) to be considered a serious offroader. Now I've seen some 200 series owners fully mod their rigs and take them down some gnarly trails, so it can be done...but IMO, for that kind of $ spent, you're better off going with an old 80 series or 100 series or a 4th or 5th gen 4runner and saving quite a bit.
That said, if you want a moderately capable offroader than can also tow and take your family on trips, the 200 series is hard to beat if you're willing to spend the money.
OP here. My has this thread taken some interesting turns.
The thread is making me lose interest in the LC, frankly. I really appreciate the utilitarian nature of the older LC's. I love the 100s (overall package, size, looks, capability). While I know the 200 would ultimately be the rig to depend on if I was going on an African safari with no backup and couldn't afford for anything to break, I'm not.
My driving is 99% road. I do some towing. I haul a bunch of stuff. I run in snow up to the mountains some. I'm on mellow dirt roads out at our cabin. Seriously if the 4r had more grunt (torque), it'd be perfect. I agree w/the folks saying the LC isn't worth the cost and complexity just to get torque.
Plus, I like my cars "as light as they can be while doing what I need them to do". I buy forged wheels because I hate unsprung weight. I removed AC from my old GTI because I could feel the difference. I just can't get past the extra 1000lbs in the LC. That means more gas, bigger engine, bigger brakes, and ultimately beefier components all around. The 4r is pretty proudly minimalistic, which I like.
I'd give a nut for a turbodiesel. My buddy is having a Discovery 110 turbodiesel restored for him over in England and shipped over. I'm going to be drooling over the torque, Im' sure.
Thanks everyone. Sticking with the 4r. The LC itch is *gone*, unless I find a low mileage 100 unicorn out there.
This topic got me thinking more about ground pressure and some calculations...
I will probably start another thread after I get some real data from my truck. But here is a chart to introduce the idea...
This chart assumes a 285/70 ish tire and makes some additional assumptions that may not be all that accurate, but I think the general thrust of it is correct. It gives you an idea of what vehicle weight and tire pressure have on ground pressure (in psi).
As a side note... (this may seem counter intuitive at first...) but increasing tire size does not directly decrease ground pressure. You have to drop the psi of the tire to actually get a bigger footprint and lower ground pressure (assuming flat ground similar tire construction).
If you take one thing away from this chart... Don't run at road pressure offroad and then complain about how your rig performed....
For refrence...
Avg Human 8psi
M1 Abrams tank 15psi
ATV 2psi-5psi
This chart assumes a 285/70 ish tire and makes some additional assumptions that may not be all that accurate, but I think the general thrust of it is correct. It gives you an idea of what vehicle weight and tire pressure have on ground pressure.
What exactly is "Ground Pressure" being measured in?
Jhunt
