CookieRoe
Senior Member
Transfer case actuators (V6 or V8) have a tendency of failure due to non-use. Another thing that will kill them is if you have a leak (or if the breather tube is done). Anyway, is there anything that can be done proactively (apart from exercising it). The only thing that comes to mind is taking the cover off (being especially careful not letting the gears fall out) and spraying WD40 in there to "loosen everything up" ??
