Tekonsha Prodigy Installation for Idiots?
cmj685
Guys,
Just got a new 2005 4R and did not want to yank the brake control out of the old car so I thought I would have the prodigy installed in the new vehicle (a plug-in type harness came with the vehicle in the glovebox). Talked to four different hitch places--every single one of them wanted to put either the drawtite 5100 or 5500 (Activator and Activator II) on. When I finally got one to say he would grudgingly sell me the prodigy and install it, he wanted $171 for the unit and about $100 for the install. I was stunned, since I had seen the unit on sale on the web for about $100 and I understand that the 4R is prewired and all but ready for plug in. I decided that maybe I should buy the unit myself online and try to install it myself. This ought to be a real comedy! So I am looking for your expertise:
1) Any reliable place on line you might recommend to buy the unit for a reasonable price, preferably a place you have actually purchased from?
2) Can you give some "Installation and Wiring Instructions for Dummies" to a guy whose expertises are all in different areas? I mean, these have to be REALLY simple instructions!
3) Where is a good place to locate the unit, and do I understand rightly that the unit can be plugged and unplugged to take out when not in use?
Any other helpful info would be great! Thanks.
Thanks for any help!
DaveS said:
It looks like there is a specific cable to connect the controller to the pre-wired Toyota harness
http://www.tekonsha.com/bch3040.html
Yes there is a connector with wires that plugs into Toyota harness. This cable came with my 4Runner. FYI, when you buy the Prodigy you will get a small CD that has some (general) installation instructions. When you watch this CD (i used my laptop computer) see if you can recognize what vehicle they are installing the Prodigy in.
Also was nice to see a 4Runner on this CD towing a travel trailer.
I ordered a prodigy several months ago for $100 plus reasonable shipping. The prodigy come with a harness with open ended wires. You should already have a second harness with your 4runner. You can either splice these two harnesses together (it's real easy) or buy a pre-made harness as mentioned.
Put the prodigy where you want and you're plug and play ready to tow after calibration with your tow load.
Hello cmj685
I installed a brake controller on my 04 Runner last year. As you state, the wiring harness is in the glove box, as it a wiring diagram. I simply used the instuctions from Toyota's wiring harness, and matched the corresponding wire from the brake controller, then plugged the unit in. I doubt if the entire job took 20 minutes.
Hope this helps
