Terragrapplers or BFG A/T's
NateDawg
80% on road, 20% off road. More city crap than anything. 265/75/16, 3.4l 4x4. Which tire would be better for me. Offroad im covering nature trails pretty much. nothing crazy, just good ole fashioned trailing. Which one? Leaning toward Nittos, but not quite sure.
terragrapplers all the way, everyone has the BFGs. i use to have them back when i was stock height, and they were nice but these grapplers are amazing!
GrovePark023.jpg~original
BFGs have a slight durability edge off road but the Nittos aren't weak and I have yet to hear of any obvious downsides to the Nittos and after 20k miles and plenty of off roading my Nittos still look new.
On-road there's really no comparison,the Nittos easliy are a better choice in the dry and the wet.
I've driven on three sets of BFGs and I'll never again. Also,why is it BFGs cost and arm and a leg more? They aren't that much better.
Well, being a year from graduating high-school, I suppose I need a tire that is better for road manners. Nittos, that is ;-)
Nittos are a good choice
I just put Nittos on my 99 SR5. I am experiencing some rubbing at the front wheel well against the factory mudflaps (now removed) and still slightly touching the splash shield inside the wheel well
with the LT265/75/16 size, only when making a turn and compression of the shocks.
We just recently had a lot of moisture and these tires do very well in the wet. The ride is slightly better than my old P265/70/16 and the road noise is almost non-existent.
Discount Tire Direct online had the best price I could find $121 for the D series and $131 for the E load rated series.:awais:
thanks Ron for the reply.
I did try to Private Message you about a week ago since you are close by. Not sure if that did not go thru. I am inept at this type of thing.....
Would you anticipate I will be able to return to using the mud flaps after a few 32nds of tread are worn off the new tires?
I have noticed significantly less spray onto the body of the vehicle since going to 265/75s from the 265/70 series tire even without the mudflaps.
