I have a 1999 4Runner limited 4x4. The check engine light has been on a little while but the vehicle has been running fine all except the fuel mileage has dropped.
I had advance auto parts check the code which he said '"Left bank running rich/lean".
After reading through the threads on this website most recommendations was that it was probably a dirty mass air flow sensor. This made sense because I had this problem before. I bought a Spectre cold air induction system and during installation the MAF sensor has to be transferred to the new intake pipe. I took this oppertunity to clean the MAF with CRC MAF cleaner. I also went ahead and replaced the spark plugs since the vehicle was almost at it's 30,000 mile interval. Once everthing was installed I reconnected the battery, let the engine idle for 10-15 minutes before I took it for a drive.:thumb3:The cold air kit makes the 4Runnner sound like my '77 Trans Am when the 4 Barrel kicks in.
I topped off the fuel tank and after a few miles driving approx 15-20 miles The fuel gauge starts dropping. The Haynes service manual reads that one symptom for bad mileage could be "Ignition Timing". Could this be possible?
When the accelerator is pressed to the floor the acceleration seems real sluggish, like something is holding it back. Since ths vehicle has no distributor , how do you adjust the timing?
