Test drove two 4th gens last weekend...
SupraTuRD
Hello,
I am brand new to this forum and so far, I'm very impressed with the wealth of information that is available here. I've been very interested in the 4Runner line up for quite some time, and plan to purchase one in the near future.
Last weekend, my gf and I drove a '04 V8 SE, and a '04 V6 Limited. The differences in the way the two drive are incredible. Despite the V8 being rated as 10hp less, it has so much more throttle response than the V6. I would be very curious to see an actual dyno sheet of the two... but by feel, the V8's torque comes on at a very early rpm range. The V8 is rated as having about 40 ft.lbs. more torque, but it's definitely spread over a wider range than the V6. The 5spd auto in the V8 might be helping here as well. The V6 truck got going pretty well once it was at a higher rpm. The V6 is no slouch and seems to be a very nice powerplant.
Based on the way the two trucks drove, I'm definitely leaning towards the V8... especially since we'll be doing some towing with it. My concern about the V8 models is the harmonic driveline noises that people have been complaining about... has that issue been resolved? As I understand it, a TSB has been issued for the lexus version, but not the toyota version.
I'm thinking that it might be a wise move to just wait for an '05... which should be coming out very soon. Also, are the rumors about the VVTi V8 true? 280HP would be fun!
ak
Don't forget that the V8 has the 5-speed auto, which has a stronger 1st gear ratio, resulting in greater pull from a stop. The first few gears are also more aggressive than the 4-speed auto in V6. This plus stronger torque band in the V8 result in what you describe.
I agree that the V8 has way more power than you might ever guess just by reading the peak power figures out of a magazine.
True, if you floor them both, the V8 is really not going to be but a few car lengths ahead of the V6 by the time that you've reached "If a cop sees me I'm going straight to jail, no questions asked" speeds.
But realistically... how many of us really care to floor our SUVs every last time we take off from a stop light?
In the real world, the V8 gives much more enjoyable throttle response and a very smooth effortless power delivery without having to rev up high at all.
And furthermore, the V8 is a proven bullet-proof design. The V6 is a newcomer to the scene and while its durability is an unknown, if you look at the technical specs between the two motors, you'll see the i-Force was designed and built with much more of a "no cost spared if it means a potential reliaiblity issue at any point in this vehicle's life whether that's 50,000 miles or 500,000 miles" attitude. The same attitude that has made so many loyal fans of Toyota over the years.
There's a reason why the V8 is the only available motor on the GX SUVs. And considering the V8 only costs an extra 1200 dollars or so, plus gives you an upgraded automatic transmission with an extra gear for highway cruising. And you end up losing, what, 1 MPG? Not a bad trade, IMO.
And yes, the V8 will be getting VVT-i, which should make the power curve even prettier and should make the most common thing I keep hearing from people looking at the 4Runner today "Why does the V6 have more horsepower than the V8??" very incorrect.:D
I have a 2005 Limited V8 2WD on order and its expected delivery is sometime in December, so I'm guessing that's right about the time that you'd get yours if you order soon.
Threxx,
If you were faulting the V6 for it's new design, then you have to consider that the 5-speed auto tranny on the V8 model is also brand new. In all likelihood, both V8 and V6 powertrain will be made to last...it's Toyota afterall. Toyota knows how to make a lasting engine and transmission.
V6 makes more HP than V8 because V6 has the latest engine technology...the V8 up to this point does not. V8 dates back to 1998 when it was first introduced in the Land Cruiser. No changes has been made since that time. We will see what 2005 will bring to the V8 in terms of extra power.
The Lexus GX uses the V8 because of the competition it's up against. Lexus has a V6 SUV already in the RX330.
As for gearing, the 5-speed auto has a more aggressive first few gears, BUT the overdrive gear is very similar between the two trannies. Therefore, highway driving should be similar in terms of tranny gearing.
Thai said:
Threxx,
I'm not necessarily saying it being new is a fault. It's actually a benefit in some lights, as is obvious by the fact that it manages to make more peak horsepower than the V8. But it's also more of a question mark. The 5-speed auto tranny may be 'new', but it is largely related to the 5-speed auto that Lexus has already been using for a while now. The feel between the auto in my GS400 and the auto in the 4Runner is near identical except for the 4runner having a little less slack when shifting (causes snapier less 'smooth' shifts, which I actually prefer anyway, as it feels more 'positive). I even, unfortunately, felt my least favorite characteristic in the 4Runner I drove - a problem I have with my GS400. You'll be driving at about 5-10 MPH and coasting or braking, but you won't actually come to a complete stop. The car could easily smoothly accelerate in 2nd gear, but instead it decides to start out in 1st gear no matter how gentle you are on the pedal, thus causing the engine to akwardly rev up until the torque converter catches the revs back up to match your current speed and then you're jerked back in your seat. It's really not that bad, but it just feels like you're needlessly getting on it in the middle of your driveway or parking lot when you really aren't.
The V6's block and whole design is really brand new and not related to any previous Toyota V6 that I'm aware of. The i-Force is, at least in some basic ways, related all the way back to the original 1UZ V8 found in the 1990 LS400. A basic design concept that has been improved upon and refined for more than 14 years now.
Don't get me wrong... the new V6 is a drastic improvement over the previous 3.4L... I just think that if I had to put my money on one based on what I've seen of the forged internal bits and overall design... the i-Force w/ 5-speed auto is a little more proven of a combo in terms of reliability... even if the extra gear and better daily-driving low end power is not enough of a selling point for 1200 bucks.
As far as lexus not using the V6 in the GX... the 4.0 V6 and its tranny are worlds apart from the 3.3 both in power curves but also in their overall feel. Even if Lexus was still worried about having a different V6 in both models, I think they should be more concerned with the fact that people shelling out the big bucks for the LX470 are getting nothing better in the powertrain department than their smaller GX counterparts. I'm guessing Toyota/Lexus plans on remedying this soon though.. especially with their new engine plant being built in Alabama.
If you want to tow or offroad get the V8, but wait for the 05's to be out. The 05 V6 might have the 5 spped gearbox as well, which means both will have the same gearing.
The overall gearing in the V8 is quite a bit lower in the first 3 gears I think and slightly taller in the highest gear. FOr towing and wheeling it makes a big difference plus the fact that you have a bigger engine for torque and engine braking.
If those two criteria aren't too important take your pick on what you like. I believe the very early teething problems on the V6 have long been resolved.
The new V8 should be a killer as it should resolve the weakest point on its power curve high RPM kick downs on the highway. It's good today but can be better as it needs a bit more breathing high up.
Just a few things:
Actually, the 5-speed auto is brand new to Toyota. It's a fresh design. Sure, it is similar in many aspects to other Toyota 5-speed (and prior 4-speed). You can't say that it's the same because you "feel" the same. To put in perspective, Toyota did not use the 5-speed auto until last year (2003). 5-speed auto has been available in Toyota/Lexus cars since at least 1998. Toyota chose to stick with 4-speed auto in the Land Cruiser in 1998 because the 5-speed auto was just a car auto.
Well, you can't fault a new design engine simply because it's new. Technology has changed quite a bit since 1998 (when the V8 was introduced). (Most engines are designed a few years before production.) Most SUV engines nowadays use aluminum block without compromising it's durability. Even HD trucks use it now because of it's weight savings and ability to dissipate heat better than iron block. Internals?? Well, i have not read anywhere that the new V6 internals are weaker than the V8. If anything, new technology and design probably result in stronger internals without the weight penalty. It doesn't make sense that Toyota takes a step back despite technology going forward.
Here's another clue...why does V8 cost ONLY $1200 more (don't forget about the 5-speed auto that comes with it)???? Is it because the V8 is cheap to make OR is it because the V6 is expensive to make?? I would bet on the latter explanation.
Yeah, the V8 is based on the old LS400 engine. Well, couldn't you say that the new V6 is based on the other Toyota engines (those with VVTi and aluminum block)?? So, what's the difference?? Saying that it is based on the OLD LS400 engine is not a good argument to be honest with you.
Why is the new V6 engine better than the old 3.4L V6?? Because of engine power?? Well, doesn't that go against your argument with regard to the V8 (since V6 makes more HP than V8)?? But, wait, the old 3.4L V6 has an iron block and is based on the same design as the i-Force V8. So, if the V6 is better than the 3.4L V6, then doesn't that mean that it's better than the V8 too (by design)??
As far as Toyota is concerned, the combo of V8 and 5-speed auto only started in 2003.
As for differences between LX and GX, where do i start? The LX is a legend...and it's frame is second to none in the world! Have you seen the LX flex it's stock suspension off-road?? It will make you run out and buy one! :) According to FourWheeler magazine, the LX470 suspension has the HIGHEST ramp travel index of ANY vehicle with an independent front suspension! In fact, it will outflex the Jeep Grand Cherokee and the Jeep has solid axles front and rear. It will outflex my MB G500 (and i have both solid axles). The only SUV that it will lose to is the Land Rover Disco. Trust me, no GX will come close to the LX's suspension flex, including the new GX with KDSS. And i doubt that the GX's frame is as stout as the LX.
For more info, please see this thread:
http://www.toyota-4runner.org/showthread.php?s=&threadid=4676
Just wondering? The current 4.7 V8 is a great engine but when you look at the fact it is only putting out 235 HP and 325 ft/lbs of torque it is way under stressed which I am sure helps it last a long, long, time and contributes to its durablity/dependablity. The VVTi will add HP and complexity, that should mean it will shorten its life expectance and could impact it's durablity. What are your thoughts about this? Is my logic flawed?
Pitbull, i doubt it. Most engine blocks are overengineered...remember, both V6 and V8 engines can withstand TRD supercharger applications, which are more stressful on the internals and block than VVTi. VVTi mainly increases efficiency of an engine.
I doubt that VVTi alone explain the increase output for 2005. I would bet that the '05 engine will have a higher compression ratio. What does this mean?? You may be required to use PREMIUM fuel...instead of just a recommendation. Would this be out of place?? Not really since most other competitor's V8 engines use premium only...see BMW and Mercedes V8 engines. The only SUV/truck engines that still use regular are the Americans. However, this is changing too since domestic higher-output engines require premium also (see Escalade and Hummer H2).
Thai, I would love to see some tech information comparing the LC/LX frame with the GX/4runner frame. Like you said the LC/LX frame is a 1998 design and the GX/4runner frame is a 2003 design. I read one of the reviews you posted on the 4th Generation 4runner where they parked the 4runner on 3 tires and were quite amazed at the fact it did not flex. Aren't the frame rails made from one piece of metal using that new process (I forget what the name is) the process is new in the past couple of years, it makes the frame rails much stronger even if they are not as large. Then they added 9 cross members, which I think is more than the LC/LX. I think your right Toyota just keeps on improving the product line and then they use the improvements across the entire product line no matter the cost of the vehicle example $60K+ Lexus LX470 same 4.7 V8 as the 4runner 4.7 V8.
You mean, "hydroformed"?? I thought that the TLC also has 9 crossmember?? Well, there is not much info on the GX frame besides what you have read on this forum. However, the TLC frame was the strongest of any production vehicle back in 1998 as per Toyota. Could the GX's frame be stronger now?? I don't know for sure...but wouldn't Toyota have said something about it being the strongest now??
As simple test I always use to look at the stresses a engine goes through is looking at the max RPM and normal operating RPM and times that by the stroke length of the engine. This gives you a good idea of the avrage piston speed an engine endures while driving it hard and in normal operation. Piston speed is one of the big factors engineers use to determine stresses on the engine block (old sub as some people would say) components, such as conrods, main bearing and crank. Obviously piston weight plays in the eqution as well. This is sometimes more stressful than boosting the piston pressure (i.e. compression and forced induction)
Now if you look at the good ol' V8 it revs to 4800 maybe 5000 on a good day, normally puts round at 2000 RPM. It has a stroke of 3.31". The V6 will run to 5500 and probably normally run at 2300 or so, 300 RPM more (gearing and torque curve) and it has a stroke of 3.74", on top of that it has 660cc per cylinder vs 587cc for the V8 which implies most probably a heavier piston as it needs to be bigger. Add (or should I say multiply it up) 13% longer stroke, 10% more avg RPM and probably a heavier piston and you will know the V6 deals with about 25% more stress than the V8 from a physics perspective.
So the cards are stacked against the V6. That being said maintenance and driving habits can quickly equalize that. Either way if you take care of the engines they will most probably outlast the useful life of the vehicle.
Note they both have the same bore, so the piston weight will probably be similar.
I don't really have time right now to go over all the points, but a couple I wanted to bring up. How is the old 3.4L V6 at all related to the 4.7L i-Force beside the fact that they're both cast iron blocks? The 3.4 commonly has intermitent head gasket failures and such anywhere from 80 to 150k miles. I've yet to hear of even one such story from an i-Force.
The 4.0L 1UZ-FE has been proven to be one of the most durable engines in the history of the automotive kingdom. It will outlast the Lexus cars into which it was placed, and that's saying a lot since the cars are designed to last forever as well.
Lastly, I've driven an LX470 and was not impressed by the frame. Very prominent 'wet noodle' feel to it over bumps. Now as you mentioned, this can be a good thing when off roading as it allows the large-bodied SUV to conform to its surroundings. But I really have a hard time believing it's as stiff as the 4Runner/GX. The 4R/GX, as already brought up, has hydroformed fully boxed in frame rails with (it was stated 9, but I think it's one more) 10 cross-members.
When Chevy (in 99), Dodge (in 02), and Ford (in 04) went to hydroformed frame rails, they saw between 250% and 400% improvements in torsional rigidity and between 30 to 80% improvements in bending rigidity. That's huge.
Then we get to the fact that the LC/LX weighs quite a bit more than the 4Runner, and weight works directly and inversely with frame rigidity (take the same exact frame with half the weight on top of it and it will be twice as stiff), and then consider that the LC/LX has one fewer cross member (the version before present-day had only 6)... and you'll see the odds are stacked pretty highly in the 4R/GX's favor for having an overall higher natural resonant frequency and less overall bending in the frame given the same scenario.
Threxx,
The 3.4L V6 was based on the 4.7L V8 in terms of design and construction. Check the specs (it's a "mini-Me" of the 4.7L V8)! The head gasket was fixed early 1997. Since that time, the 3.4L V6 has been bulletproof. I have no idea where you came up with 150K mile limit. Proof??
Ok...the old Lexus engine is durable...are the new ones not??
Why does V8 cost ONLY $1200 more (don't forget about the 5-speed auto that comes with it)???? Is it because the V8 is cheap to make OR is it because the V6 is expensive to make.
"It will outlast the Lexus cars into which it was placed, and that's saying a lot since the cars are designed to last forever as well."
Where did you get this info??
Testdriving a LX470 allows you to comment on the frame?? Wet-noodle feeling...hmmm, could that be the suspension?? Maybe it's because the LX470 suspension is more tune for a soft ride??
Weight and frame strength?? And what does number of crossmember have anything to do with rigidity...this is not always true. For example, my G500 has ONLY 6 crossmembers and weighs as much as the LX470. So, does that make the G500's frame weak?? I don't think so. How about looking at the diameter of the frame or thickness of the frame?? Or how about whether the crossmembers are boxed and welded?? Or how about the type of steel used (high-tensile)?? There's a lot that goes into frame strength than just number of crossmembers. Last time i checked, the LX470 has 9 crossmembers (i will confirm it tonight).
And you are assuming that the LX and GX/4runner frame is the same (except for the number of crossmember). Really??
The unfortunate thing is that most people do not see where the extra $$ went into the LX design. Again, read the link:
As for Ford's frame getting stronger...have you seen the crap that they made before?? Have you seen the crash test of the previous F150??!! Most of Ford's frame prior to the "hydroformed" era were not even boxed! Most were C-frame. The crossmembers are often not welded and were also not boxed. So, no, i am not impressed with Ford's new data. Toyota LC/LX470 frame is infinitely more advanced than any Ford's frame.
Thai said:
Threxx,
I knew at some point that the head gasket problem was fixed. The 150k I gave was the max range that I usually hear about the head gasket failures taking place on those 3.4s. It is not a limit for any of the 3.4s after they were fixed.
I'm not sure where I said or even implied this. If I did, I was in a rush typing last time so sorry. The new 4.3L V8s are really no different than the 4.0 except for the extra .3 liters of displacement, a little better torque curve, and a 32-bit engine control management system instead of 16-bit.
I really don't know. But by the same logic you could look at the Chevy Silverado. It costs roughly the same to upgrade from the 4.3L V6 (extremely old\dated ableit tried and true, yet underpower designed) to the LSx-based V8s (4.8 or 5.3) which are much newer designs with more 'improvements' over the 4.3L than one could possibly count including aluminum heads and such. Yet the new age V8 is only $950 (sticker price) than the old 4.3L V6.
I guess from owning one, having several friends who own them, and from being a very active member of clublexus.com and seeing that pretty much nobody there has ever had the 1UZ-FE or 3UZ-FE fail at any amount of milage unless it was because of something like overheating (radiator failure that went unchecked for a long time) or something crazy like the oil change place not putting the oil drain cap back on.
Do you own an LX470? If so then great, but if not then you really have no more validity in your opinion of the feel of the frame than I do. And no, it was not the suspension. I'm pretty familiar with the difference between suspension dynamics and frame dynamics - enough to be able to differentiate the two from any decent amount of seat time in a vehicle. Again, I'm by no means saying hte LX470's frame was piss-poor. Just that it was not as rigid feeling as the 4R/GXes I've been in.
What didn't you understand? Weight directly correlates with frame strength given the same vehicle and same frame. I did not however say that they use the same frame or anything close to it.
Sigh. Do you just like to argue or something? OK let me lay this out for you. Hardly anything in the automotive kingdom is true 100% of the time. There are always "ifs" or "ands" or "buts". I simply added that fact as a comparison between the two frames. We're never going to get the Toyota engineers to disclose the actual resonant frequencies for each frame, so for now all we can do is compare and contrast what little information we do have. Watch for trends in that data, and then draw a conclusion of probability based on that. ie: "The 4Runner is a much newer design, has 1 additional cross member, weighs less, and most importantly has hydroformed frame rails all of which the LX does not, so we might surmise that by the surface specs, the 4Runner frame will achieve at least a little better rigidity given all other factors being equal"
I agree that there are other specs that matter as well, but unless you have specific specs for both the LX and the 4Runner with all of the other specs you mentioned, then what's the point of even arguing over them? While we're at it we might as well consider that that LX's frame is spread out over a much larger distance and supporting a much higher weight, so even if the rails were thicker or the steel was higher in tensile strength, it may end up being a moot point.
Unless I had a typo, I did say earlier that the LX has 9 cross members. And I did look that up, so I'm pretty sure it's correct.
When did I say this? First and formost obvious is the hydroformed side rails, not to mention the drastic difference in dimensions, cross members, and so on.
I already read it, but there was nothing objective in there at all beside "this is better than that" "that is better than this". How is that any better than the statements I've been making in this thread? Sure for 1998 it was the strongest frame in the world for any body on frame vehicle in its class, but do you realize what incredible advances have been made with frame design since then?
I have no doubt that by some measures, the LX/LC is worth the extra money. I never said it wasn't. I just said in terms of frame strength it was not as impressive in my book and you took off with that fact and eventually started defending the LC's superiority as a whole. Well I sure hope it's better if it costs that much more.
My GS400's frame was great when it came out in 1998 - extremely solid compared to other models on the market. The same exact frame is still used even now for the 2004 models (and will be until the all new 2006 comes out). But the 2004 Acura TL most definitely is a more solid architecture now, and that's at a 30k dollar selling price while my car is selling for 50k+. Just because it's more expensive doesn't mean it's always better.
How do you keep going off on these defensive tangents where you take something I said and seem to take offense to it and then start defending something completely opposite of what we were even talking about before?
Ford had the greatest increase in overall rigidity (they were the 400%)... they were not boxed in before, now they are. The LC wasn't boxed in either until its latest redesigned. I fail to see the relevancy this has to anything.
As it stands I've presented you will several facts:
The 4Runner is a several year newer design
The 4Runner weighs less
The 4Runner has smaller dimensions
The 4Runner has one addiitonal cross member
The 4Runner has hydroformed frame rails
All of these are factors that seperate the 4R from the LC. Yet you keep telling me that there are other factors as well (which is true). But these factors could either help the LC's case, or end up hurting it further. And the fact remains you do not have any of this data in any objective format that can relate to real-world performance.
So until then I guess we'll just agree to disagree with you apparently making the assumption that since the LC's frame was declared the strongest in the undustry in the late 90s, and because it costs more, then it must have significantly higher strength steel and higher quality welds in order to make up for the factual deficiancies I've already brought to the table.
And if that's the case then great, we agree to disagree. If you'd like to continue further, please bring some actual data on tensile strength and weld quality from one vehicle to the next rather than make assumptions.
Or better yet, if you could somehow dig up the bending and torsional rigidity or natural resonant frequency specs for each vehicle, that would be great too.
SupraTuRD said:
Any word on the harmonic droning issues that the V8 models are/were experiencing at around 70mph?
ak
I thought that was diagnosed as a driveshaft issue (or am I thinking of something else here?), and the dealerships had the appropriate fix. I would hope that if the dealerships were equipped with the fix, then the new models would come equipped with the fix from the factory. Then again it wouldn't be the first time Toyota (or any other company for that matter) has decided it would cost less for the dealerships to fix it for anyone who complains than it would to retool their assembly line.:D :(
Threxx,
Ok, the 4runner has NINE crossmembers. Hmm, did you count the spare tire carrier as a crossmember?? :D It's NOT. A crossmember is usually welded, not bolted. See this link:
http://uhaweb.hartford.edu/htruong/2003_4Runner.pdf
Page 13.
Hmm...150k miles for head gasket failure in the 3.4L V6...but wait, there was a national recall for that at end of 1996 (3rd gen 4runner came out in 1996)...so WHO do you know that still had a bad gasket at 150k miles??!! It must be someone who is living in the deep woods with no connection to civilization and no mailbox!:D
Do i smell a bit of exaggeration on your part?? Yup, that's the smell! :D
You said that the old Lexus/Toyota engine will outlast the car...so what?! Are the new Lexus engine any worst?? If not, then what's your point????
See, in your arguments, you keep on bringing other manufacturers which does not make any sense. What do they have to do with Toyota?? Toyota has been using boxed frame longer than most (if not all) American companies. Why are you even mentioning the previous gen Land Cruiser?? Aren't we concentrating on the current gen vs. 4runner?? I don't get your point.
Do i own a LX470?? No, but i have off-road with one many times...my brother has an '01 LX470. We are an off-roading family ('01 Disco, '03 Rubicon). So, i have seen what the LX can do. So, i do have a good point of reference.
Why do you mention weight and frame...and then now say that both don't share the same frame?? So, what was your original point??
If new is better than old, then WHY ARE YOU ARGUING THAT THE V8 IS BETTER THAN V6??? Contradicting yourself?
As for hydroformed frame...where does it say that the 4runner has this? I have not come across this info. Can you show me please?? I thought that this was mainly used by the American manufacturers.
Threxx...i didn't say that the TLC has better welds, etc. I just said that you have to consider MORE when talking about frame strength.
Finally, Threxx, aren't you assuming too much also?? I mean you started this whole discussion because YOU ASSUME that the V8 is better than V6...so, where's your basis?????? Sometimes you say that new is better...then other times, it's the opposite?? So, which is it?? You should be a politician! You went so far as to "create" an extra crossmember for the 4runner....:D
I am listening.
