The 4th gen TRD PRO wheel picture thread
How do you like the K02's? Thinking that might be my next tire. I had the old version on my jeep and they were pretty good and I've only heard good things about the new ones.
So far they have been a good tire, not as much road noise as I was expecting with them either. They actually ride better than the stock Bridgestone's that came on the truck. And obviously give the truck a more aggressive look.
Another tire I've been hearing good things about are the Nitto Terra Grapplers, but I haven't personally ran them so I can't say one way or another on them.
Is a lift and/or spacers required for these wheels on the sport edition?
I had just installed a lift prior to installing the wheels and tires. The wheels themselves wouldn't require a lift or spacer, it all depends on what size tires you plan to run. My tire size (275/70/17) do rub slightly on the fenders, I need to push them in a little. wheels spacers will help push the wheels out a little which will make them flush with the fenders.
Got these done this week. It was time for new tires and I went ahead and swapped the Limited wheels with the grey TRD Pro ones. Had to remove the front mud flaps and trim a bit, but I am very happy with how they turned out!
Album here
Does anyone have Gray T4R with the gray wheels ? I want to get an idea of what it would look like. Can't decide between black and gray...
I have a 08 Urban Runner. Should I have any problems installing these? They should fit fine? And I believe I can use my OEM lug nuts from my other wheels?
Im trying to decide where to buy them. I have found a few OEM parts stores, Amazon, Toyota of Dallas TRD shop.
Any recommendations as to who to buy from.
My 4runner is black. Not sure if I want to go with the gray or black wheels?
I just registered here, and already see I'm part of a club!
Here's my 2007 V8 Sport Edition on stock X-REAS, TRD Pro wheels, and 265/70R17 Goodyear Duratracs.
Looks great! My wife says we need to do black wheels on our SR5, but I told her we need to lift it first...maybe not after seeing this!
That truck is looking so good man. I usually don't like chrome on the 4runners , but that chrome grill in the first pic you posted looks perfect on the truck . I'm on the fence right now wether to just get bigger tires for my 18" limited wheels or get the trd wheels and new tires . I gotta see how much extra money I have when the time comes .
My 2004 4Runner went through 3 different rims. I really like the TRD pros the best.
I had the limited rims on but once I found out the pros were available for purchase I got rid of the limited.
I have been thinking about getting new wheels for my 08 4Runner, and I think the gunmetal ones would look great. Would these be a direct replacement for the stock 17" wheel size? I have 265/65/17 tires and would hate to replace them since they are only about 6 months old? Would any suspension work be needed to fit these?
I really like the look of these wheels. I can't decide between the gray or black for my 2006 Shadow Mica...any thoughts?
Your tires would fit perfect. The only difference is the TRD Pro wheels are a half inch narrower which is not very noticeable, and they have a positive offset, so your wheels will sit wider about even with the fenders. They won't rub at all with your current tires, but if you get a more aggressive tire like mine posted above, you'll have to modify your fender liner and take off the front mud flaps.
I like the username, I used to have a 72 Cuda.
And yes, these are 17" wheels and would work with the tires you have.
I have a 2006 Sport Shadow Mica, and I'm leaning toward grey. I just bought my wife a 2014 Porsche Cayman, so I think I can buy anything I want for my T4R for at least the next few months.
I have a 2003 limited 4wd and was considering putting on the graphite trd pro wheels (it's black) Mods include a camburg entry level lift, so its got bilstein 5400s all around with camburg uca's. Camburg reccomends 285/70/17 tires. could i fit these under it without rubbing? Im looking for the edge of the wheels to line up with the edge of the fender. Thanks!
Mike Sargent
