li_runner said:The best 4 or 5?
I'll be realistic here at your meaning of "best" you can spend as much as your truck is worth on a single amp if you wanted to.
I would say realisticly the Audison LRX 5.1 is a no compromise SQ amp. Worthy of using active vs passive to your speakers.
There are very few manufactures that make good 5 channel amplifiers, most people spit the work of amps, using 1 or more for mids & highs and using one for sub(s).
Clemsonfan15 said:Alpine's 5 channel is just as good as JL's in my opinion.
You want to spend a ton of money on a nice amp, but are putting in a Pioneer sub? That kind of negates the nice amp.
Clemsonfan15 said:I agree that you don't to invert your subs, definitely does not look stock. I think you will need to do a good bit of work to get a truly factory look.
Do you know what size sub you want to go with? I would assume 10".
I posted a few subs that you might want to check out in my last post.
Clemsonfan15 said:Solid choice. I'm almost postive you will get more than 150 RMS from that amp. Are you going to run your front speakers off of two channels and then bridge two so that you'll feed the sub ~300?
Are you only looking for a 8" or are you going to build a custom enclosure? You could probably do an awesome fiberglass enclouse that fits in the stock location. That would allow you to fit a larger sub.
Have you thought about adding any sound deadening?
