The Josh's Build Thread
Guess this means I won't be getting my ARB/3rd from you till then. :(
on another note.... bent axle?? I sure hope that 3rd isn't damaged.
some updates on my truck finally:
i had alot of work to do to prepare for my new parts so i started with removing the third member which wasnt as easy as it was supposed to be. with the bent axle it took about 2 hours alone to pull out the axle shaft from the bent housing. i was able to pull out the third member the night before and sold it. i completely removed the axle and set it aside then i pulled the front suspension which i also sold.
tomorrow my new fenders will arrive so i will fit them up and then find a paintshop to paint them. and on friday my axle is scheduled to arrive and im incredible excited to see it after all this wait. the only thing i have to figure out is how to get the old axle shafts free from the brakes. according to the manual i will need a press but if someone can point me in the right direction that would be aweome
D7K_5380_zps4474369c.jpg~original
D7K_5389_zps2dde2fa8.jpg~original
D7K_5387_zps3941de9a.jpg~original
D7K_5385_zps49768cd8.jpg~original
D7K_5384_zps043cd5de.jpg~original
D7K_5383_zps6de04193.jpg~original
D7K_5381_zps863aba8f.jpg~original
i painted up the exposed bits yesterday so they are nice and shiny and maybe the gloss will help the mud slide off! i am going to piant a few spots in por15 to make the finish last alot longer
D7K_5391_zpsddc96eab.jpg~original
D7K_5392_zps4864ead6.jpg~original
D7K_5393_zps4102994d.jpg~original
D7K_5394_zpsebfcdd23.jpg~original
D7K_5395_zpsfd849908.jpg~original
So fresh and so clean!
Sucks about the bent housing though :/
EDIT: Correction, The whole accident sucks! Shame to see such a nice truck take that hit.
I think it's gonna be even better than before, if it could get any better lol can't wait to see it all put back together! Nice work josh!
Your frame looks better than the brand new one Toyota put under my Taco !
Sucks about the accident but it looks like you are making lemonade.
thanks guys i appreciate it!
im getting more and more excited as the days go on and i get more done
update today i got a amazing delivery
IMG_20130207_145723_zps6cda2b2b.jpg~original
well i got quite a bit done today, more than i was even hoping to get done.
i was able to get the pinion angle completely dialed in exactly as the tc is. then i set up all the links with a digital micrometer and i was able to get the links within 0.001" of each other. then i installed the springs and jacked up the axle and set it on jackstands so it can sit on its own weight.
next up we installed the axle shafts and proceeded to reinstall the parking brakes. the driver side went on cleanly but when doing the passenger side we found that a few springs were missing and they must have gotten lost while the shafts with at the machine shop. so that will have to wait til monday.
for the front i got started on replacing the bearings but got held up by not having the 30mm socket to take off the hub nut so that will also have to wait but i did install my new icon skid plates and changed out all the diffs fluids and removed 2 of the 4 skids plates.
file_zps67f41b89.jpg~original
waiting on glassworks fenders (which arrive monday )
file_zps48c7b7ec.jpg~original
icon skid plates
file_zpsdabca37d.jpg~original
file_zps670a364c.jpg~original
axle shaft in, e brake installed
file_zps384b58db.jpg~original
file_zpsc27cecff.jpg~original
file_zps69de369d.jpg~original
tonight i finished up running the brake lines and abs lines. definitely a task to make them look clean and routed efficiently. also adjusting the e brakes was a big task in itself. according to the manual there is supposed to be a hole you can adjust from but i couldnt find it on either side.
when i was bleeding the brakes i ended up discovering that one of the front calipers was tweaked so since im so deep into it now im just going to replace both front calipers tomorrow.
its coming along god but i have quite a bit left
new watermelon brakes
D7K_5433_zpsbb495847.jpg~original
D7K_5435_zps97c00bf1.jpg~original
D7K_5436_zpsb9c306df.jpg~original
The new axle shaft hub flanges don't have the factory access hole. I ran into the same issue installing new shafts in the factory housing. Just had to work around it. I had to adjust the star wheel on the adjuster then place the rotor/drum on to see if it was tight enough lol. I kept doing that over an over until I got the e brake set close enough.
That explains it haha!
I did the exact same thing as you did to adjust them
tuṣṭāva
