The Silver Pig
Muppet
Well I just picked up my first t4r. A 1992 sr5. It has 265000 miles on I and I paid about $1000 for it. The interior is nice and I plan on using it for my work vehichle. It's a little banged up on the drivers side but othe than that it runs strong.
Some pics.
All of the electrics work. And all the glass is good. And I recently replaced the plugs and the wires. It runs strong but the previous owner put some 33" tires on it. So the low end leaves much to be desired.
My plans:
New bushings all around
New cat
New intake
New front seats
New front drivers QP
Hood louvers
New radiator
New radiator shroud
So yeah,
Tiny
Just curious why your replacing all that stuff if its running strong? the shroud cracked? I can understand bushings but why ur intake? Good deal for a grand tho.. and front seals? are you talking about the main seal or cam seals?
yeah the shroud and the intake are cracked. The radiator mount welds have broken as well. Mainly just preventative. and as far as seals go, I'm not sure what you're talking about.
I'm going to replace the front seats, not the seals.
lol ok I just read wrong.. yeah that same weld came loose on my radiator also and took out my shroud and 3 blades off my fan.. but my truck was needing two motor mounts aswell so it was super shaking..
