The whole set LED bulbs upgrade guide - Toyota 4Runner 2006~2013
lasfit
official vendor
Are you looking for the LED bulbs to update the halogens but not sure which LED bulbs will be compatible with your 4Runner? Here we list all the bulbs size for 2006~2013 Toyota 4Runner for your reference. We also list all compatible LED bulbs which have been tested several times and work great.
A Whole Set LED bulbs fit for 2006~2013 Toyota 4Runner
If you would like to try switchback fog lights, learn more details in this thread:
https://www.toyota-4runner.org/lasfit/303418-lasfit-switchback-led-foglight-bulbs.html
1. Low beam bulb size: H11
2. High beam bulb size: 9005/HB3
3. Fog light bulb size:
● 2010~2013 4Runner: H11
● 2006~2009 4Runner: 9006/HB4
4. Front turn signal light bulb size: 1156A(single filament bulb)
5. Rear turn signal light bulb size: 7440A(single filament bulb)
6. Rear Brake/Tail light bulb size: 7443R(dual filament bulb) - DON'T fit for 08-09 4Runner
7. Backup light bulb size: 921/T15
8. License plate light bulb size: 168/T10
9. Trunk light bulb size: DE3175 (28mm festoon LED bulbs)
10. Interior dome light bulb size: DE3175(31mm festoon LED bulbs)
11. Interior map light bulb size: 168(T10 LED bulbs)
12. Interior door light bulb size: 168/194(T10 LED bulbs)
NOTICE:These are all OEM bulb size, if you have installed after-market assemblies, the bulb size may be different.
Slowly going through and replacing mine. The truck had pretty much no lights that worked beside the headlights. Don't know the PO even drove.
When I bought my '06 the headlights and brake lights worked and that was it. Dark inside, too. I don't know how a person can live with something like that. I know I can't.
Lasfit Switchback LED foglight bulbs
What about the tiny shifter illumination bulb?
This is a great thread -- I was just searching for one like it a week or two ago for my 2003
We're glad this thread is useful for you. Will you replace the stock halogen bulbs by yourself? If you run into any problems while installing, feel free to contact us for support.
Not sure about the headlights yet -- I'm more interested in the interior lighting, running boards, etc.
Will there be an 03-05 list/kit available in the future?
Okay, we'll take your suggestion into consideration.
I have checked the bulb size for 03-05 4Runner, and I list them below
1. Interior lights
* Dome light: DE3175/31mm
* Map lights: 168/T10
* stepwell light: 194/T10
* Trunk light: DE3175/31mm
* Vanity mirror lights: DE3021/28mm
2. Exterior lights:
* Low beam bulb: 9006
* High beam bulb: 9005
* Fog light: 9006
* Front side marker light:
* Rear turn signal light: 7440
* Front turn signal ight, there two bulbs sizes: 4157 and 7440. You need to check your stock halogen bulb size.
* Backup light: 921/T15
* License plate light: 168
LED equivalents?
Lasfit,
Thank you so much for this helpful thread.
Could you also possibly provide the same specific info (LED equivalents) and possible sources for each of the backlight bulbs for the HVAC control panel (2007 Toyota 4Runner SR5)?
OEM bulb numbers:
90010-09015
90010-09016
90010-09017
90010-09018
90010-09019
Thank you!
Lasfit,
OEM bulb numbers:
90010-09015
90010-09016
90010-09017
90010-09018
90010-09019
Thank you!
If you want to get someone's attention you need to either quote them or "mention" them so they receive a notification, I will mention [MENTION=675931]lasfit[/MENTION] for you.
NVBASSJUNKIE
