CoMarc
I found the below listing on Craigslist and thought it might be a nice starting point for doing the Tacoma front end conversion (after a bit of work from an auto-body shop). Here's the ad: Craigslist. It's got everything else I'd want in a 4Runner.
So I went down to it and took a look for other damage that we can't see via the ad. below are some of the pictures I took. The engine still runs and works fine. I wasn't able to test drive it, but we did start it up and I watched if run, revved it, and looked for any leaks. From those pictures, would this be a good buy to try and fix up and put the Tacoma front end on?
The part that worries me the most is in that last picture. Behind and in front of the wheel you can see a bit of the frame which is bent. Do think think that this may lead to more problems with the truck? If not, would this be pretty easy to fix so that the bumper could be put back on? Any other concerns you all can think of?
Thanks ahead of time!
