97BlackAckCL
Elite Member
There isn't a thread detailing all the steps to remove the third row seat, or to install a subwoofer in the stock location for non-JBL vehicles. So I figured I'd do a detailed thread about it. Feel free to ask questions, it's pretty straight forward but still a bit tricky.
To start, clear out your rear trunk area
My SR5 Premium came with the side pocket which has to be removed in order to fit a stock subwoofer enclosure in that location
Clear this area out as well
To start with the removal, you will need to remove the covers and screws as well as the cargo net hook. The cargo net hook turns a quarter turn and pops out. There is a phillips screw underneath.
There are also 2 screws covered with round covers like this
Remove the round covers with a flat head or trim panel remover (there is a notch for a flat head in them). Then remove the 2 phillips head screws, they're also 10 mm bolts
Next, you'll need to start with the third row seat removal. To start this first find the 2 tie downs (I pulled my canvasback liner back, you may have a rear liner that needs removed)
Flip the tie downs up, and you will find a tab at the top that can be pried up with a flathead screwdriver. This will expose the 10 mm bolt, remove the 10 mm bolt with a socket wrench
Once you remove the bolt, the whole box will lift out.
Once both are removed, you can lift the third row seat panel up and off, it has several clips so go slow and gently.
Once the panel is exposed, you will see several 10 mm bolts holding down the metal frame bracket and rear trim piece
Remove the 10 mm bolts holding down the metal bracket as well as the rear trim piece (5 bolts total)
Trim panel screws removed
Remove the rear trim panel (after the 3 screws are removed) by pulling up on it, it's held in by about 6 clips and should lift up with some pressure. After that remove the metal panel, exposing the seats. (No picture sorry)
Next you want to remove the 2 small side trim panels, they are held down by clips
Removed
I also removed the seat belt anchor seen here to allow the panel to move easier
Next you need to remove the right metal brace bracket that covers the right seat rail. It's held in with 2 x 10 mm bolts
Once you've done this you can remove the 4 x 14 mm bolts holding the seat down. There are 2 in the rear, one in the middle channel (removed on the right seat, shown on bottom)
Removed
