Those who've painted ...
01svtL
For anyone who has painted pieces on their 4R themselves, have you gotten it to polish out and be as reflective as the rest of the body? I don't know what it is, but I've now painted the mirors and the center grill piece to match the body. The color itself is a near-perfect match. However, even after running my PC 7424XP over it several times with Poor Boys Pro Polish and then a carnuba wax, it still isn't as reflective as the factory paint on the rest of the body. What gives? Does it need more clear? A different kind of clear maybe? Should I have wet sanded before polishing?
I used the Duplicolor Perfect Match paint and clear spray cans.
I can't paint for $hit so i got my friend to paint my silver bumper pieces with the same duplicolor paint and it worked out great.
He sanded it lightly with some 150 or 220 I think, wiped off w paint thinner, waited a few minutes then painted.
It says to do light coats 8-12" away 5-10 min apart. He said he knew what he was doing and thick coats only 3-5" away about 2-4 minutes apart. He also did the clear the same way. He used 2 full cans on just that small silver piece and a full can of clear (so 4 cans for front and rear plus 2 cans of clear). It looks great! and it's just as silky smooth as the rest, no runs.
When I tried before he came over mine wasn't smooth. He said it was because I was following the directions on the can. He said holding it close and spraying thick made it smooth and glossy, I guess you just have to know when it's too thick. It usually runs on me when I try.
edit: I used his method when I painted a headlight trim piece and it came out smooth and shiny but did have one small run that is only noticeable in certain light.
Have any good pics?
