Those with 265/70/16s: What PSI do you run?
Me too. Measured cold @ 72 degrees F. Subtract 1 psi for every 10 degree reduction in temp (30 psi @ 52 degrees F). All tires are a little different. Monitor the tread wear and adjust psi to compensate. The inside should wear evenly with the outside.
33 psi Michelin CrossTerrain's. That size IS on my jamb sticker, and Toy says 32 psi. front and rear.
