Throttle body gasket #'s and questions.
Seasparrow
I am beginning to have a little bit of shake in the steering wheel at idle. So as I get ready to clean the throttle body (V6 4.0) I want to have gaskets on hand. Plenty of threads showing everything except the pukes at photobucket have killed most of the images. What about the air box side of this, is it dirty as well? When I remove the throttle body, how many gaskets are there 2? one in front one in rear. What is the "O" gasket replacement? The gasket in some videos looks like a square one? Does anyone have the part numbers?
Thanks for any help
I have never removed the TB to clean it. I use a small chunk of wood to keep the plate propped open. Then I just get in there with rags soaked with cleaner. Be sure to get the lip of the plate also. That has always worked for me.
Jhunt
