Throttle Position Sensor.....?
xcmountain80
I've read a few threads from way back (2005) about a possible faulty TPS. I have a 2002 so my TPS is a 4 prong not a 3, thereby making it not replacable unless I buy a entire new Throttle Body (TB). These are the symtoms:
No SuperCharger
At just under 300,000 miles
2002 4Runner Automatic
Slipping or failure seems to occour after 10 miles of driving in the city.
Slipping or failure used to just be dropping and surging betwn 38mph - 49mph.
Now the surging happens when at idle, 500 RPM up to 700-900 RPM
No codes have been thrown other than my standard ones that indicate a failed fuel thingy PO440, PO446.
I'm in FL so it is getting warmer hear.
Part number is 89452-35030 and is not supported through Toyota with a replacable part only a full Throttle Body. The part number ending in 030 like I have onboard is a 4 pin connector and a replacement ending in 020 for earlier models will not work because it is a 3 pin model.
I have found a few TPS's on ebay with 4 pins but am not 100% certain about compatibility.
Help.
Aaron
__________________
Funny how Toyota snuck in a few of these outrageously priced parts on 01-02's. The master cylinder being another one.
I would try junk yards and part outs first.
Hopefully this link works for you. If not just enter in your info and see what comes up.
Search Results
Edit: yep the link is dead, just go to www.car-part.com
After reading the extensive thread on TTORA it doesn't help to test it. I
have a digital tester and a needle type is best. But even then when the unit fails since it is sporadic sometimes best of luck lining up the results. I'm not throwing codes but revs are revvy. Even as I sit here I'm floating a bit. Thinking back I did get a new alternator and according to said TTORA thread resetting the ECU or changing anything electrical can trip the memory up a bit. Which might explain why this problems seems to have gotten worse.
I've always found that spending a few bucks on tools/test equipment was a much better long term investment than throwing money at parts that may or may not be the problem.
Either way good luck in getting it fixed
It is certainly not that I'm cheap and not willing to purchase more tools...c'mon can you have to many tools? The problem is not which tool it is how to find the failure. You can test the resistant all you want but the hiccup may occour and it may not. The only thing that has seemed to 100% is to have a Toyota Tech with you while driving and the unit fails.
It is my understanding that tweaking or changing the current setup will have adverse effects. More over there are more things to consider than the TPS as there is also the accelerator pedal position sensor. You can mess with both but cannot replace either without the other as they are tuned together. There is lies the issue as to why the entire thing has to be replaced. Earlier setups wasn't such a big deal (3-wire version).
This seems to be an issue of when it goes it goes and not just throwing money away.
Anyone else suffered the expensive replacement mod from a 01-02
4Runner...... and 02-04 Taco's I think.
A
That throttle body is actually one of the reasons I bought a 2000. As far as testing with an intermittent problem if it were me I would probably test with a scan tool that offered data logging. I have both:
AutoEnginuity® - OBD2 Scan Tool - Professional PC and PDA Diagnostics
and
Innovate Motorsports OT-2 - Transform your iPhone or iPod into a wireless gauge, data logger, dyno, efficiency meter and OBDII scan tool. the earlier version of that. Either of them would log that signal while the innovate piece could actually be attached to their "aux" box that would allow me to tap in directly at the signal and monitor it in real time if the need arises. Neither is cheap but both are cheaper than Toyota diagnostic fees, and both a cheaper than that throttle body is new. At worse case I would think you could put a multimeter on the dash and run some wires temporarily to monitor the signal while driving.
and
Great ideas all three, the surging hasn't gotten to God awful yet so I'm game with collecting data and triple checking.
Thank you
Aaron,
I am having issues out of my 2001 4Runner as well and we need to change the tps (89452-35030). How did you put a throttle body from a 2000 on there? I would assume you had to change the wiring in your truck somehow to use the 3 pin connector rather than the 4 pin. Basically im wondering how in the world you got the setup to work.
Thanks,
Brandon
Aaron,
Thanks,
Brandon
Brandon,
99-02 should all be the same.
XC, are you sure car-part didn't send you an 01 throttle body? From what I've always heard the 01-02's were completely different animals. The VSC and drive by wire didn't start until 01 correct?? I think that's when the big changes to the throttle body and master cylinder took place.
As far as I know that is correct as well. I can only say for sure that the 00 that I have is not the drive by wire, and has the aux cruise control unit, etc. Every picture of an 01 Engine bay that I have seen has the cruise control obviously missing so either it didn't have that option (which i don't think was actually an option to not have) or it had the drive by wire throttle body.
The '99 has a replaceable TPS. I replaced mine and just replaced one for a fellow forum member on Saturday. Not sure about the newer trucks.
However, I've never heard of a TPS failing without it tripping a Check Engine Light. Even if it's intermitten (sp?) issue, it should still store the code.
Ok thank you for adding, 00-02 4Runner, and unknown year to 04 Tacoma's. The TPS and throttle body are tune of ether and not replaceable for those years with 4 wires. The tacoma guy were having issues early on wen running supercharges because coolant runs I to the throttle body and was causing premature failure. It's a known issue but no recall was issued. Search my other topics I list the links for ttora forum where you can verify.
Aaron
I've been a lurker for a while and finally decided to join so I could dig up an old post and ask some questions.
I have a 2002 4 Runner with the 3.4 5VZ-FE and seems to have the typical TPS issues. I have not been able to find the specs for testing the TPS. Is the only option to purchase an entire throttle body?
1. http://www.teamtoyota4x4.org/archivio/1996%20to%202002%20Toyota%204Runner%20Repair%20and%20Wiring%20Manuals/techinfo.toyota.com/ileaf/02toyrm/02toypdf/02rmsour/2002/024runne/sf5vzfe/thrbod/ovi.pdf
3. Yes
3. INSPECT THROTTLE POSITION SENSOR
(a) Disconnect the throttle position sensor connector.
(b) Using an ohmmeter, measure the resistance between terminals
VC and E2.
Resistance: 1.2 - 3.2 kΩ at 20°C (68°F)
If the resistance is not as specified, replace the throttle body
(See page SF-33 and SF-34 ).
(c) Reconnect the throttle position sensor connector.
3. Yes
cremebrulady
