tic tic tic tic
phgadd
I have a 99 Runner with the V6, and I'm closing in on 200K miles. When I step on the gas, I'm starting to hear a "tic tic tic tic" from what sounds like where the front passengers feet should be. It isn't there all the time, and when it does happen, it occurs when I load up the engine by accelerating.
Any ideas what it might be? Fuel pump, or maybe a bad valve?
Nope, it doesn't happen when I'm turning. And it doesn't happen when I'm driving at a steady speed. And it doesn't vary with the speed I'm driving. It only happens when I hit the gas. And the harder I hit the gas, the closer together the tic-tic-tic-tic gets.
I seem to recall something like this happening to me about 30 years ago in another vehicle, and the fuel pump eventually failed with that one. And I don't really want to be anywhere out of walking distance and have my Runner die on me! But vehicles (Especially Toyota's, neh?) have come a looooong way since then, so I was wondering if anybody else had run into this sort of problem.
Has anybody have this happen to their Runner?
if it was 30 years ago it was probably a mechanical fuel pump. so it would not be that on a 4runner. i would get under there and see if u can see anything moving...maybe the exhaust hitting the body or something rattling. vibration from the motor might be causing something loose to rattle.
well my bosses ford pictup truck has an exzost leak and it sounds to be a tic tic tic when you acc... but its even if you bairly, bairly touch the gas.
i would just get under her and check it out
well there is my 2 cents worth
that reminds me, my bid has a f-150 and he has an exhaust leak also and it sounds like a tic or rattle. so +1 to shootmymime's guess.
Thats funny you mention the fuel pump. because I just bought a '95 and while I was putting stuff in I noticed that there was a PVC Valve and a fuel pump in new packaging.
Well, I finally took it in. I took a tech out for a test drive, and he heard exactly what I was talking about. The dealer had it for about 4 hours. Put two techs on it. They looked at everything they could thing of: exhaust manifold, missing grommets in the firewall, loose anything. They found nothing. Absolutely nothing.
They told me my Runner had almost 200 K miles on it, so putting any more time into researching the problem waas pretty much of a waste. Especially since it is running strong.
Their last word? Maybe it's somesort of metal fatigue. Just keep driving it. If it breaks, then we'll know what the problem was!
I mean, what is this? A Ford or Chevy or something? I am sooooooo frustrated!
i agree with the dealership, if the mechanicals check out and it is running good then i wouldn't worry._ it does have 200K miles so it's gonna develop some squeeks and rattles.
not good advice at all
if its something you can feel, it is absolutely not fatigue
i garuntee its your CVs and CVs do not only click turning, they click when going straight, mainly due to ADD , they turn when driving even though not powered, reason they have premature wear on the boots.
get those checked out by somebody other then that re****ed dealership.
Since we're all guessing anyway- you say this happens only under acceleration so my guess is bad motor/transmission mounts.
does it go with rpms or vehicle speed? try throwing it in neutral when u hear it and give it gas, see if the sound speeds up
When I took the tech out for a drive, we tried a lot of things, including reving it in neutral at a dead stop. The tic tic tic is definitely related to both rpm's (above 2000) and how hard the engine is loaded up. At any given rpm, if I'm cruising at a steady speed, nothing. But if I step on the gas or go up a steep hill, the tic tic tic starts.
Strange . . . Very very strange.
Wow I would have guessed exhaust leak right away.....and if that wasn't it I would go with a valve tapping......:confused:
Had the same (or similar) tic in my 2000 Taco..... it was the EGR system. A tech at work told me it is harmless and not worth repairing. It is common and does it sound like a person tapping a pencil lightly? That may be it..... If it is loud get it checked it might be something else.
Well, I just thought I'd let everybody know how the tic tic tic issue resolved itself (I hope, anyway.). Shortly after my last response, the check engine light came on. I was HOPING it was just an oxygen sensor or something, but it turned out to be both catalytic convertors!
I had both convertors replaced, and the tic tic tic stopped. I thought I'd wait a bit before I posted just to see if it returned, but so far it hasn't. YES!
Sooooo . . . if ya get a strange tic tic ticking noise, consider the catalytic convertors as a possible (and costly!)cause!
Thanks to all for your assistance!
