gman72
Well - begun to work on my old baby ('94 4WD). Next year I'll be lifting it 3-4" and possibly get a diff. lock and a few other goodies. But that's next year ... 1st is a little TLC to get her running back the way she used to.....
So far - have done the following, looking for some tips and advice on what next:
1) Replaced shocks all around
2) Replaced front CV axles (boots were torn)
3) Replaced rotors, turned drums
4) New pads & shoes
5) New bearings, inner & outer on front
Front end still seems a bit loose. Any suggestions what the most common or likely cause for this would be? I looked at the tie rod ends, ball joints, bushings, etc, ... all "look" fine but at 170K miles I'm sure something should be replaced that's causing most of the looseness?
What would you recommend, in order of importance, to help tighten up the front end more?
Thanks!
4) New pads & shoes
Thanks!
