Time Capsule 2013 Trail Edition
Was this at Lakewood Toyota?
I ALMOST flew there from Texas for a 2011 Salsa Red Trail with 55k ish miles. They were asking $26,500 and after a month dropped it to like $23k
I ended up with one like yours locally
search this forum for door actuator
Not a CPO. Yes, due to age, I reckon. I did buy an extended warranty.
There are 2 issues the dealer wouldn't fix, both are key related. 1) Driver's door lock does not operate with key, but it unlocks electronically. Diagnosed as a bad power lock actuator. 2) the rear door doesn't lock or unlock by key either.
The key fob, and one valet key both operate ignition. Related? or coincidence?
Might be a quick fix, if the actuator was replaced (it's working, as you say), and they didn't connect the door lock (I did that once) (note the torx unscrews all the way, and then the key assembly will come out, you can thread it back in correctly).
From this thread:
https://www.toyota-4runner.org/5th-gen-t4rs/242540-drivers-door-lock-actuator-motor-repair-[step-step-w-pics-].html
ok - so I answered my own question - there is a 20mm or so blanking grommet on the door jamb - I took this off loosened the torx screw behind it & this let the lock barrel come out - I could then thread the shaft back into the actuator - took 3 minutes - hope this saves someone time in the future if their keyed entry doesn't work after an actuator change! Feel a bit stupid but then doing your own car repairs is always a humbling experience at times.........
Hope the OP doesn't mind me offering this info on his post to help...
alexaturner
