Time for plugs...Which ones?
Presta24
03 v8 sr5 awd. I have 101k on it and want to change the plugs. Which is the best plug, or which are you guys most commonly using in the v8?
Autolite?
Has anyone used Autolite XP Iridium? I just went to the auto parts store and was told that these are very good plugs. They were $6.99 and there is a $2.00 per plug rebate right now.
Thanks,
~Doozi
Thanks,
~Doozi
I installed Autolite XP Iridium about 2 months ago. So far I like it. I have not had any problems starting the truck in the cold. Also, I noticed that the engine sound changed a little, it became deeper, more raspy, I guess... I like it.
Thanks for the info, snhrph! Time to head into the garage and start swapping plugs. By the way, it looks like we have similar tastes!
:cheers:
~Doozi
Plug change observations
Changed the plugs today and can only assume that the originals were still in there... 3 Denso on the passenger-side and 3 NGK on the driver-side. Mileage was 71,686. The manual says the spark plug gap should be 0.043" and the Autolite XP Iridiums came out of the box at 0.044" so I just left them that way.
These are the plugs that came out and their gaps...
> Denso (on the left, top-to-bottom): 0.054", 0.053", 0.053"
> NGK (on the right, top-to-bottom): 0.060", 0.060", 0.060"
The picture shows the plugs in the positions that they were in in the engine...
Can't really conclude too much from this, but a couple of observations would include that the NGK plugs look to have been consumed a bit quicker than the Densos and maybe the two rear plugs (top in the picture) get the hottest. Also, they were pretty tight and "squeaky" coming out so I used a bit of anti-seize on the new ones.
~Doozi
either way, not bad for 70k + i think v6 is supposed to have em done every 30k, i wouldnt think yota would use 2 different kinda plugs but i could be very wrong
Yeah... I've read that they come from the factory like that! Don't know why, but maybe someone can chime in.
~Doozi
Some have speculated that Toyota has a 50/50 agreement with both Denso and NGK for plug usage. So the best way to ensure the agreement is upheld is to use half and half in every engine.
~Doozi
I had the complete opposite happen when I changed my plugs (at 50K miles). The NGK's were like new and the Denso's looked half used. This was on a supercharged 3.4 V6.
Koz
I just finished putting NGK Iridiums in mine tonight.
I have 100,300 on it now and guess what? 3 Deno's and 3 NGK's in it when I pulled them out! It really wasn't bad, but on the driver's side we had to pull one vacuum line when we did the driver's side, and have a swivel for the 10mm on the middle coil, but other than that we could just barely get that and the back injector out with a little finesse.
Which plugs were in better shape?
Koz
Honestly, it was pretty even. They both looked about the same. I may be getting one MPG better, but I dubt it made much difference.
I just hit 59k on my original plugs. Pulled out 3 NGK and 3 Denso. Replaced them with Autolite Iridium XP. Just got the ones that Kragen/Oreilly's had listed for my engine. So far so good. No gap adjustment. Overall a relatively easy job. Removed the intake and engine cover. Also removed the top bolt on the black bracket on the drivers side. From there, the plugs weren't hard to get to.
