Time to replace my coil-overs?
atalarico
Senior Member
Hey all,
So, I have about 171k miles on my 97 Limited 4WD.
I'm trying to figure out whether or not my struts/shocks/springs need to be replaced or not.
I can't find if it's been done anywhere in the rather meticulous service documentation from the previous owner. I do know that the vehicle was serviced during the recall for rear sag. I have the paperwork. Does that mean that the rear suspension was replaced or just the springs?
Anyway, if I'm not mistaken, its time to replace the struts/shocks when the body has a hard time settling down after bumps (bouncy), there are audible crunch/clicking noises when going over bumps, or the car sags heavily. At least, that was the experience from my previous vehicles.
I do notice that my rear sags a little, but I think that's sort of to be expected with our model year 4runner, no? I don't notice it being any more severe than other 4runners I see on the road.
As for the bumps and noise, I don't seem to feel much of it. It's actually still quite a firm ride, which I think is also common for 4runners, no?
A mechanic quoted around $700 to do them all when I took it in to have the brakes looked at. I'm guessing that's using subpar/non-OEM parts, but I'll accept shop recommendations in the Denver area as well. However, I see I can get a full set of Bils for around $299 from Shox.com and that the rear are a fairly straightforward driveway job.
I was toying with the idea of doing an OME lift since I'll be mucking around down there anyway, but I'm not sure I can afford the $700 for the kit, and I don't think I need it at this point.
Thanks in advance for the advice!
I cant answer your question about sag, I never had that issue. I did break a shock though. I replaced my rears about 2 months ago, I ended up cutting one of the shocks with a sawsall due to some rust on the nut. Otherwise it was easy. Did my lift on sat, the front coil overs were even easier to get out. I'd save yourself the cash and just do it yourself.
