275,000 miles. No way I'm changing it at 90k intervals now. Glad things worked out!
So here is my related issue, I was changing my timing belt on my 99 and during the course of getting the new belt on (so much tighter than the one I did on my old Frontier), the left cam (passenger side) turned 1/3 of a turn. Didn't panic, just called a buddy who has rebuilt a few engines in his day. He just told me to turn the cam back to where the mark was realigned. Turned it back to TDC, since putting it back together it has run fine except for going up hills. There is some hesitation and power loss. What is the best course of action for determining if my timing is a hair off in the pre or post ignition? I want to do things right and screwing up is part of learning, especially when you don't have mentors. Can anyone give me an idea on this without a "take it to a mechanic" as that really doesn't teach me anything in the long run.:noidea:
I went 201k miles before I did mine. Could have went 100k more it didn't look bad. It's hard to break one els something causes it they are pretty durable.
First, you need to realize that the timing belt has nothing to do with ignition timing. That is set by the ECU and varies continuously as various sensor inputs change.
Second, if you want to verify your VALVE timing, which IS controlled by the timing belt, you can do that. First, use a wrench on the crank bolt to rotate the crank and set the pointer on the crank pulley to 0° (TDC). Loosen the clamp ring on the top radiator hose and slide it forward. Remove the bolts from the top timing cover and pull it forward so that you can see the cam pulleys. Verify that the marks on the cam pulleys are at top center lined up with the marks on the block. Disregard any marks on the belt itself.
You might want to mention that the camshaft timing marks only line up every other time the crankshaft pulley marker is at TDC.
Second, if you want to verify your VALVE timing, which IS controlled by the timing belt, you can do that. First, use a wrench on the crank bolt to rotate the crank and set the pointer on the crank pulley to 0° (TDC). Loosen the clamp ring on the top radiator hose and slide it forward. Remove the bolts from the top timing cover and pull it forward so that you can see the cam pulleys. Verify that the marks on the cam pulleys are at top center lined up with the marks on the block. If the pulley marks are at 6 o'clock, turn the crank another 360°. Disregard any marks on the belt itself.
Also an interesting note, the camshaft and crankshaft have different ratios so the initial line up of the timing belt marks are for install only. Once you've rotated, they won't line up anymore relative to the pulleys. It's important to do a few test rotations to make sure the actual markings of the cam and crank still line up with TDC.
Question: So after a few revolutions the timing marks on the 2 cams will not be lines up in relation to the crankshaft marking?
Or is it every other revolution they will line up?
the timing marks should always line up, but the lines on the timing belt won't line up.
That makes plenty of sense.....
Well, actually it IS every other revolution of the crank. On the second turn of the crank the cam marks will be at 6 o'clock and then come back to 12 on the following turn. Then 6, then 12, and so on. The crank turns twice for every single turn of the camshafts. The belt marks will realign eventually, but only after a ridiculously large number of turns, and then only once until another ridiculously large number of turns. So, after initial installation, you just ignore the marks on the belt.
Durk.... I was thinking about this last night.....
So if and when i do the timing belt the crank mark lined up, I would imagine i have to get the proper revolution. so would that would mean on the proper revolution the #1 cylinder should be TDC (top dead center)?? on the crank then line up the cam marks?
Or does it make no difference because that piston will always be up and then time the cams from there?_________
