LittleCaesar
I am just trying to figure out if you have fire on some cylinders or none on all six. Make sure the wiring around the igniter is in tact. You can pull the fuel pump relay to safely check for spark (make sure you ground the plug to metal).
With RPMs your crank signal seems fine.
It almost seems as if the problems may be in the IAC/TPS area. All are plugged in? Plunger works in the IAC (easy to test with a 12v battery)? Check for loose wires as well. Crossing those lines doesn’t make for a happy ending.
