timing belt maintnace time, please advice!!
juan_tls
So I'm changing the timing belt on my 02 v6 4runner. Here's a list of parts i'm replacing while i'm in there
All three serpentine belts
water pump
thermostat
uppper and lower radiator hoses
cam seal
timing belt
Should I do the tensioner while I'm in there? Any other suggestions??? This is my first attempt at a timing belt replacement so any and all advice is more than welcomed.
thanks in advance
Juan
if your going to change your cam seals, might as well change your crank seal. works the same way as the cams, as far as changing them goes.
