toytech76 said:There isnt any reason to do all the seals if they arnt leaking. I know some people like to replace every part behind the timing covers when they do the belts but it is entirely unneeded. If its not leaking, broken, worn out ect ect, there is no reason to replace stuff. Every 90K + for the tbelt and belts and check the other things and replace as NEEDED
Stick Figure said:i agree and disagree w/ you both! lol .... my own vehicles, i only replace what is needed. For a customer i would recommend to replace the seals, because the seals are far cheaper than the labor to tear it down again. Same could be true for someone if it is their only mode of transportation. The downtime may be better if it is planned in advance rather than if its oh %$#@ my water pump just went out and i have to work tomorrow!
just my 2
rjyhdc4 said:I don't consider it a good idea to wait until the part fails to replace it...
toytech76 said:Ok well where do you stop then? Your eng could blow or your tranny could get noisy or anything on your rig could fail. I guess you could replace the car if you are that worried about not letting things fail
Victor said:
Side note, I see we have a couple of Toyota techs here?
LINY4Runner said:got another one here! haha
I changed the t-belt, wp, cam and crank seals, thermostat, and tensioner spring. Peace of mind...*Better safe than sorry*
