Timing belt what else....
Ride_Red
Probably going to have the timing belt done on a 2000 limited with 130k. Anyone know how much this will run/what else to look for and or replace?
Thanks!
Most would replace the water pump, thermostat, cam shaft oil seals, crank shaft oil seal, and maybe the axillary belts if they haven't been done in a while. Take a look at the valve cover gaskets as well.
I'd also check the timing belt pulleys and tensioner for wear/noise. It's not the biggest deal on 4Runners because the 3.4L is a non interference motor but might as well check while you're in there.
Oh, you have a 5th gen. I'm not sure about the interference status of that motor. You might want to post in the 5th Gen section for that one
Depending on dealer/indy, location, and quantity of other parts--price can run $600-$1100--the $1100 being a total dealer rip-off in a high cost area.
Other parts include, roughly in priority order: WP, two idlers, three aux. belts, thermostat, tensioner, rad hoses, cam and crank seals (a must if leaking).
I did it DIY, all except the seals at 120K, for under $300 total, including coolant. I bought the seals but chose not to put them in.
If this is first change, I would do it all, except the seals if they are good, and go back in another ten to twelve years.
EDIT: Not a 5th gen, he's talking about a 2000.
Wow, there's a guy in Golden, CO that will do a 6 cyl Toyota TB for $360. I was thinking of going to him but does that mean he doesn't get all that other stuff (ie seals, t-stat, hoses)?
