timing
MartyH
My spouse affectionally called Huricane Debbie, was driving to work when my 1997 sr5 decided to quit. Now this is my baby. She said that she heard kind of a clacking noise from under the hood and it quit running. I have been trying to work on a problem with bank 1 lean on the scanner, but it quit before I could look at it. the motor will start and then go off. The clacking sound has me puzzled, as to what the problem is, ( other than Hurricane Debbie ) Maybe timing???. anone want to venture a good guess??
Could be a lot of things. If it starts then dies, the timing belt is still on but timing could be off. That would indicate a tensioner failure which there reportedly are none. Pull the top cover off and check the timing.
You also need to put in more info. Was their oil and/or coolant on the ground? Did it overheat? Do you have oil and coolant in the engine?
A video would be helpful. Take the skid plate off and look at the block.
Can you take a video and uploaded?
chasebradshaw
