Tire Indicator light on
05YotaGuy
Hey guys, I've got a problem with my 05 4Runner. My tire indicator light is on, but my tires are all ok. I've got 20" rims on my 4Runner also. I haven't checked the pressure on them, but from visual view they look ok. What can be the problem?:confused:
You can tell the exact tire pressure just by eyeing it eh? Get out a gauge and actually check them.
The most common suspect is the spare tire. It also has TPMS and no one seems to remember to check it. I guess most people don't put the spare into rotation (I do) or I doubt it would happen as often.
Sorry, what I meant was my tires didn't look low or flat from visual view. Is there anyway to reset the light or just check the spare tire. Then it'll reset itself?:beer:
The light should reset itself.
It's getting cold outside...
What is interesting is if you do a search on the TPMS, a good chunk of the threads start each year around OCT or NOV. How do I know? This week in southern MN we received our first low-30's temp, and my TPMS light came on. Came on here to do a little research and found that many times the light will go because your pressure(s) are down due to the cold.
So, I filled up all 5 of my tires, and now no more light.
Cold Temps=Lower tire pressure=TPMS light. Simple as that.
