Tire Minder
Link:
AccuPressure Safety Caps: similar to Tire Minder but a bit cheaper
A revolutionary new tire pressure monitoring system which will help you conveniently know when your vehicle's tire pressure is too low.
Proper inflation of your tires helps reduce the risk accidents caused by poor handling, premature tire failure, blow-outs, hydroplaning and improper braking.
Proper inflation improves gas mileage, traction and extends tire life.
No tire gauge is required. No removal of valve caps is required. No kneeling on wet or dirty ground.
GREEN when the tire pressure is adequate - within four pounds of the rated PSI.
YELLOW if tires approximately four pounds under inflated.
RED when approximately ten pounds or more under inflated.
Interesting...however, i am afraid it is a bit too easy to steal!
:shakehd:
