MurrayTheCat
I had a new set of tires installed today on my 04 SE at Costco. In the process they broke one of the valve cores trying to remove it to deflate the tire. They said it was corroded and was not their fault. I had them use the spare rim so they could finish the job. The tire is holding air, it just broke the tabs that are used to unscrew the valve core. Do you think it is ok to leave it alone, or should I replace it. Can the valve stem be replaced alone, or is it part of the sensor? The dealer was closed, any idea of the current cost? Can one be replaced and reprogrammed without having to mess with the other 4?
