Thai
Elite Member
Hey all,
I am still in my endless search for the perfect tire for me. I am thinking of going from 265/70/16 to 245/75/16...both are 31" tires. Major difference is that the tire width would decrease less than an inch.
Reason? Well, for my G500, i am looking for a more off-road-oriented tire with the same stock size (31"). I am considering Goodyear MT/R among other MTs. The reason why i don't upsize is that my spare tire cover cannot cover a bigger size. Without the spare tire cover, my spare wheel is ugly since MB mounts them with the pretty face facing inward!
In addition, there may be some issues with my stability control if i upsize.
For example, if i were to go with MT/R, then my tire diameter stays the same (exactly!) to what i have now (BFG AT KO 265/70/16). The width decreases a little less than 1 inch. Tire weight is about the same (50 vs. 51 lbs).
Most tires in 245/75/16 range are Load Range E...so these tires are for heavy duty and will easily support my G's weight.
The negative that i see beyond the different aspects of the tire themselves: less protection for my rims during off-roading because the tire is skinnier.
So, is there anything i should know about or missing in my calculations??? On-road performance?? Anything.
Thanks in advance.
Thanks in advance.
