tire recommendation needed for 2007 SR5
JCC
Discount Tire in my area says I need four new tires. The size on now are 265 65 17. Their recommendation is Cooper Discoverer HTP in the same size. I was not sure if there was an alternate size that others have found to work better or look better. I did have another locally owned independent shop recommend a little taller tire at 265 70 17. I appreciate any suggestions based on experience or knowledge.
Personally I'd use 265/70-17 from now on. It's a much easier to find size if you need a tire in a pinch, and they are less expensive also. Plus, more options. You can get a set of tires in that size for under $450 delivered to your door right now from discounttiredirect.com. I always order from them.
  • Like
Reactions: JCC
Thank you! I will consider this option. The independently owned local shop recommended Cooper Sigma HT or the taller size 265/70-17 he said Korean made Nexum Roadian HT. Both are 60k mile tires. He can put them on for $630. Discount Tire with replacement certificates was $650 or so. Not that much of a difference. I dislike having to buy tires.
265 70 17 is what I run now. I'm getting a lift installed Saturday and will change up a size. I have Bridgestone dueler AT's on it now ( I bought the t4r with them already installed) they are the worst tire with absolutely horrible wear patterns. They aren't good getting traction either.
  • Like
Reactions: JCC
Discount Tire Direct has the Cooper HTP for $146 each minus $170 in rebates. Total, $414 with free shipping. Your Discount Tire shop should match that. If not, order them at DTD shipped to you and have someone mount and balance them.
I agree the 265/70 AT tire is a little taller tire and I actually noticed quite the difference compared to the original Dueller HT tires. I ended up with some BF Goodrich and couldn't be happier. Good luck and dont forget to take pictures.
  • Like
Reactions: JCC
I will stay away from those tires. Thank you!
I will ask Discount Tire about matching that price. They are having a sale this weekend, but I will not be in town. I am sure they will have sales again. I am also sure they will be having more sales in the future. I appreciate the help.
Thank you for your help. I will be sure to take some before and after pictures. Wish I could afford to do more to my T4R.
I don't think you can beat Michelin LTX M/S2 tires on the street (well except in price). Traction, milage, etc are outstanding. I got a set of 4 at Costco for a good price and they have a $70 gift card rebate. Used them on my last pickup truck and it was a like a new vehicle when I put them on.
  • Like
Reactions: JCC
If you dislike buying tires, these or the Toyo HTs. For mostly on road driving they can't be beat and you're likely to get 90-100k miles out of a set.
DionicioLives
