Tire size question
Hello,
Found a great deal on toyo tires open country's with 90% tread on CL but the size is weird 295/75-16
Is here a reason 295's are better than 285's? Would I buy or hold out for 285's. I do have the Sonoran 1.2 but no body lift.
Thats a really wide tire! I know some modifications are required at least for the 285's. Maybe with spacers they will fit?
That is a fairly common size for the LC guys.
It will be a little taller and wider than a 285/75.
There is a pretty convenient tire calculator that has some comparison tools available on a forum about the world of tacomas under the mods & tutorials tab. It gives a pretty idea of the difference of 2 tire sizes.
Here are the results of comparing a 285/75/16/ vs a 295/75/16:
285/75/16 295/75/16
Current Tire New Tire % Dif
Diameter inches (mm) 32.83 (833.9) 33.42 (848.9) 0.59 (15) 1.8%
Width inches (mm) 11.22 (285) 11.61 (295) 0.39 (10) 3.5%
Circum. inches (mm) 103.14 (2619.77) 105 (2666.9) 1.86 (47.13) 1.8%
Side Height inches (mm)8.42 (213.75) 8.71 (221.25) 0.29 (7.5) 3.4%
Revs per mile (km) 614.31 (381.48) 603.45 (374.74) -10.86 (-6.74 -1.8%
Check out link for a table that makes sense.
285/75/16 295/75/16
Not sure which one you're talking about but the one in my sig works well as a side by side comparison.
tire converter
