Tires after lift???
ftbjoe87
Ok I have searched for a while and I am getting mixed responses. I just ordered a lift from cornfed for my 05 sport T4R. After installing the lift I will be getting new tires. I was planning on going with 285/70/17 on my stock rims but I have seen some post that say this is not possible. Can anyone shed some light on this? I dont really want to get new rims but also want the 33"s. I read on burtmans website where I bought my lift that you can go with the 285's but I have also seen otherwise in this forum. Will they rub? If they do can you fix this problem with wheel spacers? I have heard that wheel spacers are somewhat faux pas in the 4wheeling community. Thanks
Remember bigger is not always better. Do you need a 33 over a 32? Are you going for looks or if you plan to take it off road what type of wheeling do you do? I only go off road a few time a year and so can live with 32's. I had to fight the temtation to go with the larger but took into concideation the fact the 33 would hurt my millage and put a bit more stress on the rig. Just depends on your goals for the rig. Any thing other than stock is a huge step up and good driver can do just as much with a smaller tire.
What size cornfed lift did you order? That would help some. My bet is that with the stock weels, without spacers you will be cutting A LOT to fit 33" tires.
If you plan to offroad a lot, you'll learn to appreciate a larger tire. Thus 285's will be nice to have even though you gotta trim a large portion of a lot of parts.
If you offroad once in awhile, then you can't go wrong with either 275's or 265/70/17 or 265/75/16's. Hope that helps.
Regardless, the more you offroad, the more rubbing you'll encounter as you're really testing the limits of your suspension stuffing those tires up and down.
Go with what suits your needs and not what others are doing. Follow your own destiny and get what you feel works for the type of stuff you do with your 4runner.
Good luck!
The cornfed lift I got is the 3" in front and 2" in back. I am considering getting 275/70/17's but if I only need to get some wheel spacers I would definatly consider getting 285/70/17's. I plan on off roading quite a bit. I also will be going up to the mountain snowboarding so I need something for the snow. Thanks
After taking a good look at these tires I've come to the conclusion that these tires are great for off-road and only fair for on-road. If you compare these tires to the REVOs you would be sacrificing on-road handling, braking, ride, wet traction, and tread-wear. They are allot noisier, and will hydroplane easier. These tires are what they are, GREAT off-road tires. They are GREAT on rocks, in the mud and are incredibly durable. The exact diameter is 32.4", which only gives approx. 3/8" more clearance over the 265/70/17 REVOs. That 3/8" is why they touch. Yes, it looks like you won't have trim but they do touch (not an issue).
Bottom line
No-IP.com said:
You've used these tires on your 4runner it sounds like?
I'm making a conclusion from other owner's opinions (Which I believe to be the best indicators on overall performance). Also the spec data came from the manufactures. I do have the REVOs on my Taco and agree with the high ratings from other owners and other members on this site.
Koz
"Anything bigger then 265/70/17s = 32" requires cutting!
Koz"
BS - I run 275x70x17's (on stock rims with the 2.5 lift) with no rubbing and no cutting and I wheeled Anza Borrego where we lifted wheels off the ground and stuffed wheels into the wheel wells with no rubbing issues.
I have decided that I am going to go with the 275/70/17's. For the off roading that I will be doing I believe they will be just fine. The hassle of all the cutting and worrying about rubbing and wheel spacers just for another half inch I do not think is worth it in my case. Plus the 275's are cheaper. No I just need to pick a tire. I was thinking about the BFG at/ko's. Anyone with any other suggestions? Thanks for the insight.
04Runner said:
"BS - I run 275x70x17's (on stock rims with the 2.5 lift) with no rubbing and no cutting and I wheeled Anza Borrego where we lifted wheels off the ground and stuffed wheels into the wheel wells with no rubbing issues.
Every manufacture that makes a particular size tire makes it DIFFERENTLY, including size. I'm sure that the tires you're using fall under 32.4" in diameter, where they start to touch. I would recommend that anyone who wants to go bigger and doesn't want to do ANY trimming should go to the manufactures web site and take a good look at the overall diameter of the tire, and stay under 32.4" in diameter. Numbers are numbers! Also remember the spare, looks like 31.7" is about the biggest that will fit under the vehicle. You also may want to have your wheel alignment checked.
Koz
The problem I have is over your black and white statement "Anything bigger then 265/70/17s = 32" requires cutting!
This is not true, it is misinformation. It's also not too clear as many people who have moved to bigger tires speak of trimming vs cutting, so again you ought to be specific. There is no timming or cutting required for 275 MTR's in my experience, using a 2.5 spacer lift. Some people (search) find it necessary to cut a lot out for 285's. Some find some minor trimming. Depends upon what suspension and wheel applications they are using. Again it is not so black and white.
And I'm not sure if its directed at me, as it's hard to tell from your phrasing, but I had an alignment done five days ago thank you.
Koz
The fact is the 275 MTRs do touch without a lift (No trimming, but they touch). They measure 32.4" in diameter as per the manufacture. Apparently with a lift they don't. A tire that measures 31.7" in diameter will not touch. This is a difference of approx 1/4" to 3/8". Since no one that has posted a tire that measures exactly 32" in diameter that does not touch I would not assume that it would not touch.
With that said I'll be more specific: If you have a stock Toyota 4th gen. 4Runner without any lift or spacers the largest diameter tire size, that would not touch, would be a 265-70-17 that measures approx 31.7" in diameter.
Please feel free to Nit-Pick!
Koz
Koz said:
Please feel free to Nit-Pick!Koz
It's not nit picking.
The thread was about fitting bigger tires AFTER a lift. No-one was talking about fitting bigger tires without a lift:bash:
You are correct, I thought someone with a lift still had those tires touch. Sorry!
Koz
