Too much lift for CV's?
surfmobile
Okay so i need some help. here's what im running:
I have a cornfed 3/1 setup. With FJ Springs up front and OME 895's in the back with the 1" rear spacer.
I need new struts and was thinking about the bilstein 5100's adjustable. I would run them on the .50" setting.
Is this too much lift for stock UCA's?
Thanks for the input!
I have an Overland Warehouse Radflo 2.5" Coilovers at 3" right now and about to crank them up to 3.5" in the front. I also have 1.5" Body Lift. You're fine. They'll be a little kinked but the CV's are actually at a negative angle at stock.
Thanks dude ya I should be fine. I we u have a body lift. Run into any problems with the 1.5" would you recommend it?
thanks.
