Too much lift!
razzman1
Member
So I picked up this 03 V8 SR5 last year. I installed the front suspension from a 2014 Tacoma TRD, which yielded about an inch and a half of lift.
With the factory rear springs, it ended up sitting level, to slightly bro-ish, especially with gear in the back.
So I bought some 2" Icon springs from Amazon and installed them last night, and holy cow, it netted me way too much lift.
Will the springs settle enough that I don't feel like I'm driving around in a handicap van? I plan on installing a expedition style drawer system, which will add a couple hundred pounds, but I'm not sure if it will be enough. Should I try different springs? Maybe add an inch or so spacer to the front (I don't want to have to get into serious UCA mods or anything)?
They wont really sag much even with the extra weight. You will be fine with 2" lift in the front if you find a decent alignment guy if you want to add a spacer in the front.
The back looks fine. The front needs to come up. Seriously. You installed tires to big for you previous suspension. You need a pair of Bilstein 5100s ulto adjust the front up a bit and you will look great.
If I remember correctly, the tires are 265/75/16. I put about 350lbs of lead in the back last night, and it squatted down about an inch or so, and it looked much better. I think Morphyne is right--I should probably get some 5100s and bring up the front an inch or so. I have been toying with the idea of going to a Hitchgate tire carrier, so that would help even more.
Since I have the front suspension out a Tacoma, should I get 5100s for a Tacoma, or are the Tacoma/4Runner 5100s the same?
Thanks everyone.
I have the exact same suspension set up as you and was thinking about adding those ICON springs in the rear. But you are right way too much lift.
Now I guess I am going to have to spring for the whole ICON lift!!
You can never have too much lift :) sometimes a topout spacer or slight BL can help you down the road when the springs settle.
Well, looks like Down South Motorsports is going to get some of my money. I think I will just go ahead and get the full 5100 Bilstein shock kit. I needed the rears anyway, since the factory Tacoma shocks were too short.
Should I get 5100s for a 4Runner, or Tacoma, since I have Tacoma struts in it now? Or are they the same?
ETA Disregard. I see they are the same.
Well, since the Tacoma suspension was basically new when I installed it, and only has about 700 miles on it, and I liked the way it handled so much, I decided to go with a top-load spacer from Toytech. The 3/4" spacer netted me about 1 1/2" of lift, and I think it turned out looking pretty good.
IMG_0320_zpsxllkpdg4.jpg~original
[/URL]
Talyn
