Top 3 rebuildable suspensions that can handle winter time salt and whatever else
Fried_man7
Hey peoples!! Looking to expand my search criteria for my build and I wanted to know what others EXPERIENCES are with rebuildable suspensions and the evil winter time elements. I live in New England, Boston to be exact, and we believe in using as much salt and ice melting agents as possible. Yay. With that being said. I’m looking at Radflo/Fox 2.0, 2.5 and will also cater to the higher end performance of Kings and Icons. I know everything will eventually be affected but what would last the longest mixed in with occasional trail riding.
Thanks! Happy Almost thanksgiving.
None of the ones you are looking at. You could go with an OME set up but that doesn’t have any adjustment in the coilovers. Could always Fluid Film the suspension components for the winters.
Boston is the nicer spectrum of the roads that I'm on in the wintertime.
The bad news, salt is going to whip the piss out of your suspension components unless you are very proactive.
I cover up the rear shocks with shockwraps, and I had some other shockwraps modified to cover the reservoirs. Iv'e got two sets of shocks, and my winter ones go on while the summer ones kick around the workbench. I've had lots of success winterizing my winter kings... but I'm sure it looks absurd to anyone that doesn't live in this climate.
On the coilovers, I've been using icon's coilover wraps to keep the salty slush off my coils and shock shaft. They shockwraps work very well. I use boots on my rear shock shafts, as salt and sand can make a nasty pitted mess. I have the boots stretched down to also cover the lower uniballs-- this works surprisingly well.
For the fittings and threads on the coilovers, I oil them often with boeshield after my frequent trips to the heated washbays. The uniballs on my UCAs are oiled with triflo, and they're washed very often and I use compressed air to dry everything off quickly in the wash bays.
I've painted the zinc-plated reservoir brackets with rubberized undercoating spray. The zinc rubs off pretty easily, and then they rust like a bugger quickly. The black res brackets look pretty sharp.
I have zero rust on my shocks, but they are dark with patina from the boeshield. They run fantastic though.
I do a lot of winter prep to my vehicle, and repeat again in the spring. spot application of fluidfilm, rust paint, and dielectric grease... I keep it as clean as you can, and it pays off.
If this doesn't sound like something you want to spend a lot of time on, I'd recommend some cheap shocks for the winter. Otherwise, it's manageable if you're willing to go the extra mile.
Any specific questions - feel free to shoot me a PM.
For what it's worth- the new fox shocks for the TRD pro have aluminium bodies, and would not require this kind of maintenance.
The longest lasting shocks in winter conditions are non-rebuildable ones. The part that will need replacement most often are the uniball spherical bearings. They have much shorter lifespans than rubber bushings. They do make stainless ones. The problem is stainless is softer than hardened steel, so you have to choose between hardness to combat abrasion and stainless to combat the rust. In addition the loaded surface area is quite small. The result is that nether one will likely last more than a few years before requiring replacement. Rubber will last for decades.
The seals and shafts and such will probably last longer on rebuild able shocks.
It may be worth a call to falcon to see what they think about the Tacoma shocks on a 4Runner. They are about the only one I'm aware of that doesn't use spherical bearings.
https://www.falconshocks.com/toyota-tacoma. I have no affiliation. I don't know for sure whether they're a direct fit or not to a 4Runner. In generally I think it looks like a pretty nice option for a mid-price kit, but again I have not ever ridden in a truck with their shocks so I don't know what the valving is like.
Don’t buy any high end rebuildable coilovers if you live in a cold climate area,you will be disappointed after a while.
The most durable ones are non rebuildable,like Bilsteins 6112/5100 and OME.
I live in Alberta Canada and winter is 8-9 months a year here. King,Icon and Fox won’t even survive for 6 months without extremely careful maintenance in my area.
Look into ADS, there shocks are very well made and have a coating to help protect from the elements.
