TORONTO: 2004 4RUNNER LIMITED V6 4WD 385K Km $4900
lightfreak
***CAR HAS BEEN SOLD***
$4900 Canadian dollars
Well maintained, accident-free, religiously cared for and has served me well over the years.
New vehicle just arrived so sadly I need to sell it.
***COMES WITH over $1000 worth of spare parts, all brand new and all quality*** See list below
Attached are photos taken OCT 31 2020 right after detailing and treatment with Adams Spray on Ceramic Coating.
Also attached is Blackstone Oil Analysis taken at 350,000 Km
Specific pics available upon request
Highlights:
SCANGAUGE II with Transmission temperature reading
LED Interior with footwell lights, extra lighting added in the cargo area.
RIGID Dually LED auxiliary fog lights mounted inside front bumper.
Super bright Aux Reverse lights in rear bumper (JDM style assemblies). https://www.toyota-4runner.org/2661875-post6.html
Frame as been sprayed every year using various products: Amsoil Metal Protectant, CorrosionX , Fluid Film, Formula 3000. There is surface rust but everywhere is solid
XREAS removed, KYB springs/struts on front and KYB rear shocks with MOOG rear springs. Installed 2017
Weathertech Floor Liners front, Husky liners 2nd row and cargo area.
Headlights and foglights have VOSLA HIR2-9012 bulbs, much brighter than OEM 9006 bulbs.
Replaced in the last few years: Mevotech lower control arms, Walker catback exhaust, denso downstream O2 sensors, steering column u joint, hood/tailgate struts, spare tire carrier, tailgate window regulator, power steering return line, tranny-to-radiator hard lines, exhaust gaskets/bolts, thermostat, NGK iridium plugs, rear diff breather.
BRAKES are in good condition , fronts are Cardone coated calipers, Centric rotors and Centric pads. Rears have Mountain rotors with OEM Toyota pads. Left rear caliper is Cardone coated just replaced recently and right rear caliper is original. Lots of meat left on the pads.
Current problems: driver's seat leather is worn/shredded on the side, rear wiper has never worked well, driver's door courtesy light is not working, and there's a very slight exhaust leak on the passenger side.
NEW Spare parts included: 2X Jersey Built hub/bearing assemblies , Cardone front CV axle, OEM transmission pan with dipstick tube, power steering high pressure line, brake pads, various oil/air/cabin filters, lots of various Energy Suspension bushings for control arms and sway bars. Also have spare set of front calipers that need rebuilding. Great for DIY coated pistons project or for quick core exchange.
Comes with 2 OEM master Keys, 2 OEM FOBS, 1 OEM Valet Key, 1 aftermarket VW style Flip Key FOB (used for 1 year, works 100%) and 1 aftermarket Bentley style Flip Key FOB , brand new, needs to be cut and programmed.
Here's some random posts I made over the years to give an idea of its history.
Liftgate Window Regulator Corrosion
V6 Gates Serpentine Belt after 138K Miles
Window Glass Rattle Fix
https://www.toyota-4runner.org/2665754-post27811.html
https://www.toyota-4runner.org/2656670-post60.html
https://www.toyota-4runner.org/3569540-post13.html
Will meet anywhere within 2 hours of Toronto for motivated buyer.
