13 ft. lbs.:cheers:Does anyone know the torque specs when replacing the spark plugs on a '05 4Runner v6?
I'm due to replace them.
Thank you.
Rick
13 ft. lbs.:cheers:
I notice several here mention 13 ft.lbs. Just wondering where this spec comes from ? The Haynes manual says 15 and Denso says 18-21 for 14 mm plugs. That's 3 different specs
Haynes mentions anti-seize but Denso has no mention of it . Yes I'm getting ready to change mine
Densoproducts.com
13 foot pounds and no anti seize- You will need a 18inch extension to make life easy. I did mine with a 12 but wished the whole time i had an 18inch.
Not to throw more mud into the waters here, but when you add an 18" extension to a torque wrench, keep in mind that the torque value applied to the plug is different from the setting on the wrench. In other words, if you're looking for accuracy, you need to compensate for extensions.
BTW, I don't use torque wrenches to install my own plugs.....just use my own experienced hands to snug them down properly.
Not throwing mud, but some light. I can't do the math, but the longer the extension, the "more torque" you apply..........would be interesting to see how much MORE one is actually applying. I'm sure it's negligible.
When using a torque wrench with an extension, some of the torque is lost to the "flex" or "twist" of the extension. So if you were trying to tighten a fastener to 90 ft. lbs, for example, and you were using an 18" extension between the torque wrench and the socket, you would have to set the torque wrench higher than 90 ft. lbs. to compensate for the flex in the extension.
So you're not applying more torque with a long extension, you're actually applying less torque than indicated on the torque wrench. There is a simple formula to follow if you're doing precision work.
