Torque Wrench Settings
markman100
For Christmas I'm asking for a torque wrench so I can rotate my tires. I have a couple questions.
Which size should I get, 1/2 inch or3/8 inch?
What should I set it at when I'm putting the lugs back on?
Any particular type of torque wrench you like better than others?
Thanks.
I like the type where you dial in the torque setting, on the handle, rather than the pointer-indicator type. The torque for the lugs is 83 ft-lbs. I like the
Are you using a 3/8 drive with a 21mm socket? If yes, where did you get the socket. I haven't been able to find one. ] [/B]
You can use any size you want to. The bigger the drive, the less force it takes in your arms. You can even buy reducer adaptors: for example I sometimes use a
