Towbulance...lol
*Kevin C.
My first tow :(
Felt like I called an ambulance for it lol
Seems like one of the pulleys are seized.
Expensive? I hope not lol
I hope so too.
I turned it on and it sounded like a vacuum was on lol
06 T4R SE V8 4WD SM
Dumb question, but did you check to see if there was a vacuum in the engine bay? Actually sorry man. Please let us know what the issue was
Lol good one. First I thought the blinker fluid was out but then I thought no it's not that... lol
I'll give an update once I find out.
06 T4R SE V8 4WD SM
Confirm this is what it is first but yep sure sounds like air injection pump failure. PM slyfox75 and get yourself an AIP bypass kit, tricks the failed pump into not turning on and you won't get any faults.
UPDATE***
So I had a mechanic (my uncle) look at it and there is no problem, no strange noise anymore. It runs just fine now as I was told. I'll give it a start up and run tonight when I get home.
Will update again when I get home and after the test run.
06 T4R SE V8 4WD SM
Strange "vacuum" noise is gone, thank god lol
But then my back window shattered today when the defrost was on for a bit... one thing after another... smh lol
I made a another thread for the back window because I remembered seeing one about how the back window shatters after using the rear defrost. Now I can't find that thread, anyone else has had the back window shattered due to the use of the defrost setting? Did you call Toyota dealer, or just get a new window through a automotive glass shop? Does insurance cover it as well?...what did you do when that happened?
06 T4R SE V8 4WD SM
The dreaded "vacuum" noise is back and this time I was smart enough to record it [emoji2] lol
Any diagnosis?
06 T4R SE V8 4WD SM
