Hi, I am the happy owner of a 1998 4Runner SR5 V6 4WD Manual. I have already previously installed a 4-wire trailer light controller, and used it with a small trailer to transport a dirtbike.
The time has come that I am shopping for a travel trailer. I am looking to buy an 80's 17' bigfoot trailer (single axle) with a dry weight of 1875lbs, so I will guess around ~2600lbs loaded up. My 4Runner is rated for 5000lbs towing capacity and I have installed a 5000lb hidden-hitch with 500lb rated tounge weight, so I don't think weight will be a problem.
Now for my questions...
1) The trailer, I am pretty sure, will have electric brakes, so I will need to install a brake controller in my 4runner. What brake controller do you recommend and why?
2) Is there any advice out there on how best to install it in a 3rd-gen 4unner?
3) Will I need some kind of wiring harness to route my existing 4-wire lighting plug into a 7-prong plug for the trailer?
4) Will my alternator need upgrading? I read that this puts extra load on the alt, as it charges a battery on the trailer to power its brakes (??)
4) I am planning on replacing my rear diff and tranny fluids (front diff and transfer case can wait....will only be under strain in 4WD am I right?) before taking the trailer on a trip. I have been using regular (non-synthetic) gear oil 80W90 and 75W90 if I remember right....should I be switching to synthetic? Will this help the tranny under the extra load and heat?
Thank you all for your help!
Cheers,
Ken.
Cheers,
Ken.
