I must admit - had no idea my V6 would do so good! I only pulled the boat about 15 miles so far but it feels really stable, plenty of power, the brakes worked great, and on the HWY got up to 15.5 GPM before I had to turn off. I am sure it will go even higher as the average kept climbing until I turned off.
Now to my problem - the trailer had the standard flat 4 pin connector and the tow hitch had a 7 pin multi use plug in. Looking under the truck, I could see Toyota never connected this to my wiring harness under the truck. I found two connections coming from the truck one was a longer slender connection the other was a 4 wire connection which fit the connection on the hitch. I also purchased a 7/4 adapter. The brakes work and turn signals but not the running lights. These are brand new lights on the trailer and they told me they had tested the lights and they worked fine. Had a sister-in-law with an SR5 Prerunner and had problems with wiring up a u-hual. Seems like Toyota has alot of issues with the wiring. Any ideas on how to get the running lights working? I can attach pics if anyone wants to take a look see.
Thanks in advance!
Thanks in advance!
