towing
can i use a Uhaul tow dolly to tow another 4runner? i am picking up a parts truck and need to know.
UHaul has a guide on their website. I don't see any reason why you couldn't do it, but UHaul may say the tow weight is too close to the vehicle capacity. Of course check your hitch rating and tow ball rating.
I remember seeing that [MENTION=102813]SURF RUNNER[/MENTION] rented a trailer from them to haul his parts 4Runner with his 4Runner.
Might have to tell them you are pulling a civic. Sometimes they are weird if the vehicle is "too big" stupid uhaul
Since ya' got the Ford trans cooler and especially if towing on mostly level ground in Floriday, I say No problem.
Might want to monitor trans temps via say Torque.
When I town with mine (only about 3000lbs) my highest trans temps happen after repeated stops/accelerations to 50mph then stopping and repeating again and again. Other than that once up to highway speeds no problem (but i have no big Ford cooler). Luck and enjoy. :cowboy:
don't have means to monitor temp. driving will be 90% highway and country.
I remember seeing that @SURF RUNNER rented a trailer from them to haul his parts 4Runner with his 4Runner.
I told U-Haul that I was hauling a 1977 VW Bug the first time and a 2010 Mini Cooper the second time.
Agreed, just tell them it's a Civic or something. Put the towed 4Runner up front first onto the dolly, then unbolt the rear driveline from the rear flange. I used a tie-down to hold up the driveline into the frame. No problems towing mine, however I didn't tow mine with another 4Runner.
why do this? neutral won't work?
Neutral will allow you to move but it is still rotating parts in the trans while no fluid is moving so it will burn up the trans real quick.
don't know. what is that? i'm a novice to towing.
It's a device built in to the hitch of the tow dolly that applies the trailer brakes when the tow vehicle slows down. I don't know if tow dollies have them or not. They're common on big boat trailers.
If the dolly doesn't have brakes I think I would still tow the T4R as Toyota rates the base truck to tow some 5K pounds. I would keep the speed down though, use low gears on downhill grades and keep my distance as stopping distance is likely to be long.
You have an '01 so it can deliver many engine stats via the odb2 port.
Here is what ya' need:
1) An app like Torque costs $4.95 (there is a free version).
2) Then you need one of these: https://www.amazon.com/Version-Blue...e=UTF8&qid=1472119554&sr=8-1&keywords=327+elm
Simply attach the bluetooth unit to the odb2 port under dash by right foot and connect to the torque app and configure. It'll give you real time temps that you can use to adjust your driving and use of OD override to throttle the trans temps. Luck on the tow. :cowboy:
Can't you tow the 4runner by putting the transfer case in neutral? Then the automatic transmission isn't spinning at all.
Part of transfer case will be spinning unlubed gears via the input from the rear axle. This has been the case with Toyotas since at least the '80s.
