Toyo lift and level?
Augdog1964
Ok guys... the Salsa Red TE has finally made it to my dealer...and the black leather with red stitching is in place.
I have to take my toytec lift over tomorrow for installation... I did a search and found a couple different opinions... I want a small amount of rake, 1/2 inch or a little more lower for the front...
So is it 3 inches on the front and 2 inches on the back to accomplish this, or 2.5 and 2? Another amount? Am I backwards? LOL
I'm doing Nitto terra grappler 285/70r17s I believe on the factory TE wheels... or have considered 275/70r17s with a little lower lift?
thanks for the advice!
Dave Bane
Augdog1964
Dave Bane
Augdog1964
Mine came with a factory rake of 2 inches higher in the rear. I run my Icons at 2 3/4" front and 1 1/2" rear to give me about a 3/4" rake .Barely noticeable!
Which Toytec lift are you getting as they have a few? Probably the Ultimate and is adjustable in the front up to 3 inches and with the rears a 2 inch spring lift.
You'll still probably have some minor rubbing that you'll have to take care of with the 285's. Probably on your front mudflaps......no biggy!
Congrats and good luck!
Toytec Ultimate
Its a toytec ultimate lift... I'm going to have them try a 2 3/4 front like you suggested Harper, and 3 in the back.
3/4 rake sounds good!
Dave Bane
Augdog1964
Dave Bane
Augdog1964
Dave , I meant to say oem rake is 2 inches higher in the rear,not the front and I just corrected it in my post.DOH!
Your Toytec rear springs will give the rear a ~ 2 inch lift and is not adjustable. Your fronts are adjustable and will give a maximum of ~3 inch lift. So if you run them at 3/2 ,you will have a 1 inch rake with the rear about 1 inch higher. That's what most people have .Hope that explains it better!
My rear springs are SAW's and only give 1 1/2 inch lift in the rear instead of the 2 inch of the Toytec springs. That's how I am able to get less rake. I was looking more for overall less height to make sure it will fit in my garage with a rack and lights up top.
If you click on the Icon link in my sig. it's explained a little better with pics.
