hey no input have you stupmped well here is some more went back to it agian the owner stopped last night and we bled brakes the old way pumping up oh buy the way i found a leak above the shock bracket filled with dirt fluid finally seeped so i could find it by accident replaced lines from mid section to hose and both cyls any way bled system no pedal brake light came on why no prop valve this morning went out had one quarter pedal no brake light on the dash had this happen before air began gravity bleeding no air now no pedal again used one man bleeder on system nothing at all went over all connections tight tried bleeding the abs nothing seems to make a differance nobody here has any input?
**vehicle was brouht to me with no brake fluid in master cyl looked over no leaks but found calipers froze hoses cracked rear shoes not making contact no leaks replaced calipers hoses and master cyl no leaks at master also pedal stiff then fades to the floor pressure bled gravity bled no brakes went to dealer not any help cant find any load sensing valve brakes adjusted no weak wheel cyls bled good clean fluid booster dry where did fluid go and whats up with no pedal any body out there got an idea
