seems like pretty much the same problem
Hello to everybody,
it seems like, that I may have pretty much the same problem. I was already helpless and yesterday was the forum down, so I couldn't read this thread here. So I prepared already a post for starting my own thread for the specific prob. I'll copy past it here, just to have it complete if somebody has that much time, for google and there are a few more questions in the text...
(sry for not reworking my prepared text, as I'm right now already damn tired from my day - its already next day here in Down Under
but first, I miss one link with hadia's problem. I have that problem only,
when the engine is warm. and it stalls only when engine is more hot after had it stopped for a few minutes.
so my question is now, does it really makes sense, that the throttle position sensor is influenced by the temperature?? I don't have much ideas of how that item works, thats why this question.
I probably will get this part anyway, because, and here it comes...my car gave earlier already a check indicator with the message: problem with TPS. but at this time, I hadn't much problems...
here comes the full story plus videos:
After introducing me and my car
here, I need your serious help. I suggest to read my introduction post, at least the car history to maybe link problems and for better understanding of the timeline...
What is my serious problem right now?
My engine stalls/ shuts off by itself in idle. This only happens when the engine is warmed up (coolant temperature indicator reaches normal middle position) That it stalls, happens so far only after I stop the engine for a few minutes (for example at petrol station). Why it happens? Because the idle is to damn low! It’s struggling rough like: 800 > 500> 200 > 500 > 200 > 800 > 200 > 0!
my idle was ok in the past - and it still is, as long as the engine/coolant temp. gauge does not reach the normal middle position. I conscious recognize the struggling since my old radiator blew up. After that the stalling happens first. Anyway, I prepared a few videos, maybe it helps
DSCN1654 - YouTube
After 20 minutes, 20km daily drive. Idle struggles a little, but I think, not to bad in this moment. At one intersection before, it was already struggling around 500rpms…
Actually, I was never to much concerned about the rough movement of the engine block (see at around 0:40) before. To understand this, with yesterday I got my first conscious comparison. After changing my spark plugs and starting the engine then (cold), it was damn smooth. Four hours before, when I arrived, I let the engine running in idle to flush my oil (prepare for oil change) and my mate was like „what is your engine doing? Why so rough? Shit?!“ but ya, I have not much experience with old cars, so for me it was always looking normal, or better said, normal for an old car.
DSCN1655 - YouTube
After shutting down the engine and let it stay for around five minutes. At around 0:30 to 0:40 and around 1:00 it’s best to see, how rough/shaky the engines runs. Totally different from smooth cold start. Sry for the bad sound quality, and unfortunately the camera grabs the knocking even more detailed than all other sounds (rough running, as you would here in live)...
DSCN1657 - YouTube
Just one more video. Here the problem already with starting.
I
definitely link this problem to the temperature, because the idle struggle most worse when the engine was shut off for a while - that means with it the cooling system > whole engine heats up under the hood, as because there is no more cooling. the indicator never shows unnormal temperature of the coolant. So it’s not over heating. All other driving is normal. Engine runs and I can not complain about the performance in any way as long as I push the pedal... . Seems like, there is one part/item, that doesn’t like warmer temperature and is linked to the idle set?
When having a look in the full 3VZE repair manual I just saw “cold start injector time switch” and “cold start injector” ...seems like, as long as the engine is cool, these parts doing whatever they do in detail in their correct proper way, but as soon as its becomes warm enough for the engine and these items are not any longer involved in the engine running process the part which takes the task from one of these items, has a problem... any specific suggestions for that specific problem? (when using google, I found a few other helpless owners with recognizing the same symptoms on their V6s – but I couldn’t find a specific solution. All what I see and understand so far, let me think, there is just one ****ing thing that goes wrong and it is kind of a typical 4Runner sickness...damn it?!
I’m happy and thankful for all your time and advices.
