toyota 4runner 1995
Take off the wheels, take off the hubs, pull the brake calipers, pull the CV axles, disconnect the sway bar, disconnect the tie rod ends and ball joints, unbolt the a-arms and remove.
I might have missed a small step or two. I'd budget at least a long afternoon to remove and replace each side. You might could do both sides in a day if you'd done it before and didn't run into any stuck bolts. Are you actually changing the a-arms, or just installing new bushings?
7ron
